[GRASS-dev] [GRASS GIS] #2434: v.surf.bspline: WARNING: Unable to rename null file / WARNING: Unable to write quant rules:
write quant rules:
  Reporter: baharmon | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: major | Milestone: 7.0.3
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords: v.surf.bspline, raster, quant
                         | rules, null file, cell file
       CPU: OSX/Intel | Platform: MSWindows 8
Comment (by glynn):
Replying to [ticket:2434 baharmon]:
My main suspicion is that this is caused by the DBMI driver process being
spawned after the output raster is opened (so it inherits a handle) and
still being alive when Rast_close() is called (similar to issue #2775).
If the driver inherits a handle to the temporary null and cell files,
renaming them will fail as the files will be "open".
If that's what's happening, either the close-on-exec flag needs to be set
on those files, or DBMI drivers need to close all open files between the
fork() and the exec(), or the DBMI driver needs to be terminated before
closing the raster.
Also, see the "Open/close db drivers order" thread (ca Oct 22) on the
grass-dev list for some more discussion of this.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2434#comment:21&gt;
