[GRASS-dev] [GRASS GIS] #2434: v.surf.bspline: WARNING: Unable to rename null file / WARNING: Unable to write quant rules:
write quant rules:
  Reporter: baharmon | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: major | Milestone: 7.0.3
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords: v.surf.bspline, raster, quant
                         | rules, null file, cell file
       CPU: OSX/Intel | Platform: MSWindows 8
Comment (by hellik):
Replying to [comment:21 glynn]:
> Replying to [ticket:2434 baharmon]:
> My main suspicion is that this is caused by the DBMI driver process
being spawned after the output raster is opened (so it inherits a handle)
and still being alive when Rast_close() is called (similar to issue
#2775).
> If the driver inherits a handle to the temporary null and cell files,
renaming them will fail as the files will be "open".
> If that's what's happening, either the close-on-exec flag needs to be
set on those files, or DBMI drivers need to close all open files between
the fork() and the exec(), or the DBMI driver needs to be terminated
before closing the raster.
> Also, see the "Open/close db drivers order" thread (ca Oct 22) on the
grass-dev list for some more discussion of this.
Author: annakrat
Date: 2015-12-05 06:51:04 -0800 (Sat, 05 Dec 2015)
New Revision: 67020
Modified:
    grass/trunk/vector/v.surf.bspline/main.c
Log:
v.surf.bspline: move opening raster after opening driver, closing is in
reverse order, attempt to fix #2434
tested with
System Info
GRASS version: 7.1.svn
GRASS SVN revision: 67023M
Build date: 2015-12-06
Build platform: i686-pc-mingw32
GDAL: 1.11.3
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
g.region -p region=rural_1m@PERMANENT res=2
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 220750
south: 220000
west: 638300
east: 639000
nsres: 2
ewres: 2
rows: 375
cols: 350
cells: 131250
(Sun Dec 06 15:33:21 2015) Command finished (0 sec)
(Sun Dec 06 15:33:38 2015)
v.surf.bspline --verbose input=elev_lid792_bepts@PERMANENT
raster_output=elev_lid792_rast ew_step=5 ns_step=5 method=bicubic
lambda_i=0.1 memory=900
Input is 3D: using z-coordinates for approximation
Cells for raster map <elev_lid792_rast> will be interpolated
Initializing output...
Adjusted EW splines 121
Adjusted NS splines 131
Processing subregion 1 of 4...
16805 points found in this subregion
Processing subregion 2 of 4...
13741 points found in this subregion
Processing subregion 3 of 4...
13512 points found in this subregion
Processing subregion 4 of 4...
11564 points found in this subregion
Writing output...
v.surf.bspline complete.
(Sun Dec 06 15:33:54 2015) Command finished (15 sec)
so it seems to work now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2434#comment:22&gt;
