[GRASS-dev] [GRASS GIS] #2434: v.surf.bspline
Reporter: baharmon | Owner: grass-dev@…
     Type: defect | Status: new
Component: Raster | Version: svn-trunk
Keywords: | Platform: MSWindows 8
      Cpu: OSX/Intel |
I got the following error with v.surf.bspline:
v.surf.bspline input=ground@lidar raster_output=lake_raleigh_dem_bspline
ew_step=6 ns_step=6 method=bicubic lambda_i=0.02 memory=12000 --overwrite
Initializing output...
WARNING: Unable to rename null file
'C:\Users\Brendan\Documents\grassdata/nc_spf/lidar/.tmp/unknown/3624.1' to
'C:\Users\Brendan\Documents\grassdata/nc_spf/lidar/cell_misc/lake_raleigh_dem_bspline/null':
Permission denied
WARNING: Unable to rename cell file
'C:\Users\Brendan\Documents\grassdata/nc_spf/lidar/.tmp/unknown/3624.0' to
'C:\Users\Brendan\Documents\grassdata/nc_spf/lidar/fcell/lake_raleigh_dem_bspline':
Permission denied
WARNING: Unable to write quant rules: raster map
<lake_raleigh_dem_bspline> is integer
v.surf.bspline complete.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2434&gt;
      Cpu: OSX/Intel |
Comment(by neteler):
Two questions:
  * how big was your computational region (approximately)?
  * is the mapset directory locally or mounted via network (check
permissions in that case)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2434#comment:1&gt;
      Cpu: OSX/Intel |
Comment(by baharmon):
The computational region is approximately 4000 ft sq or 1.2 km sq.
The mapset directory is local.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2434#comment:2&gt;
      Cpu: OSX/Intel |
Replying to [comment:2 baharmon]:
We'd like to know the number of rows/cells as well.
ok.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2434#comment:3&gt;
      Cpu: OSX/Intel |
Replying to [comment:3 neteler]:
Should be approx. 1300 x 1300. I'll check on Monday.
> ok.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2434#comment:4&gt;
Keywords: v.surf.bspline | Platform: MSWindows 8
      Cpu: OSX/Intel |
Changes (by neteler):
  * keywords: => v.surf.bspline
Comment:
If you can, please provide a North Carolina dataset example.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2434#comment:5&gt;
      Cpu: OSX/Intel |
Replying to [comment:5 neteler]:
I used the nc_spm_08_grass7 dataset to recreate the issue. Here are the
steps I took:
d.vect map=elev_lid792_bepts@PERMANENT
g.region vect=elev_lid792_bepts@PERMANENT res=1
v.surf.bspline --overwrite input=elev_lid792_bepts@PERMANENT
raster_output=elev_lid792_bepts_bspline memory=12000
(Mon Nov 10 11:43:02 2014)
Processing subregion 1 of 16...
Processing subregion 2 of 16...
Processing subregion 3 of 16...
Processing subregion 4 of 16...
Processing subregion 5 of 16...
Processing subregion 6 of 16...
Processing subregion 7 of 16...
Processing subregion 8 of 16...
Processing subregion 9 of 16...
Processing subregion 10 of 16...
Processing subregion 11 of 16...
Processing subregion 12 of 16...
Processing subregion 13 of 16...
Processing subregion 14 of 16...
Processing subregion 15 of 16...
Processing subregion 16 of 16...
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/.tmp/unknown/7332.1'
to
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/cell_misc/elev_lid792_bepts_bspline/null':
Permission denied
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/.tmp/unknown/7332.0'
to
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/fcell/elev_lid792_bepts_bspline':
Permission denied
<elev_lid792_bepts_bspline> is integer
(Mon Nov 10 11:46:02 2014) Command finished (2 min 59 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2434#comment:6&gt;
      Cpu: OSX/Intel |
Replying to [comment:6 baharmon]:
steps I took:
to
Permission denied
to
Permission denied
Just wanted to note that I ran this again using the user1 mapset rather
than from the PERMANENT mapset just to follow best practices. The result
was the same:
(Mon Nov 10 11:51:15 2014)
(Mon Nov 10 11:51:16 2014) Command finished (0 sec)
(Mon Nov 10 11:51:30 2014)
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/.tmp/unknown/7556.1'
to
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/cell_misc/elev_lid792_bepts_bspline/null':
Permission denied
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/.tmp/unknown/7556.0'
to
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/fcell/elev_lid792_bepts_bspline':
Permission denied
(Mon Nov 10 11:54:28 2014) Command finished (2 min 58 sec)
Command 'd.rast map=elev_lid792_bepts_bspline@user1' failed
Details: Fontconfig error: Cannot load default config file
Raster map <elev_lid792_bepts_bspline@user1>: format field
in header file invalid
Ticket URL: <http://trac.osgeo.org/grass/ticket/2434#comment:7&gt;
      Cpu: OSX/Intel |
Comment(by hellik):
Replying to [comment:7 baharmon]:
the steps I took:
to
Permission denied
to
Permission denied
was the same:
to
Permission denied
to
Permission denied
confirmed here with:
System Info
GRASS Version: 7.1.svn
GRASS SVN Revision: 62657
Erstellungsdatum: 2014-11-08
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
(Mon Nov 10 20:23:05 2014)
v.surf.bspline --verbose input=elev_lid792_bepts@PERMANENT
raster_output=mytestrast memory=10000
Input is 3D: using z-coordinates for approximation
Zellen für die Rasterkarte <mytestrast> werden interpoliert.
Initialisiere die Ausgabe...
Adjusted EW splines 150
Adjusted NS splines 150
8785 points found in this subregion
12132 points found in this subregion
11562 points found in this subregion
9385 points found in this subregion
10376 points found in this subregion
14703 points found in this subregion
14656 points found in this subregion
10855 points found in this subregion
13453 points found in this subregion
15950 points found in this subregion
16042 points found in this subregion
11484 points found in this subregion
7861 points found in this subregion
9337 points found in this subregion
9184 points found in this subregion
6968 points found in this subregion
Schreibe Ausgabe...
'C:\grassdata/nc_spm_08_grass7/testspine/.tmp/unknown/7528.1' to
'C:\grassdata/nc_spm_08_grass7/testspine/cell_misc/mytestrast/null':
Permission denied
'C:\grassdata/nc_spm_08_grass7/testspine/.tmp/unknown/7528.0' to
'C:\grassdata/nc_spm_08_grass7/testspine/fcell/mytestrast': Permission
denied
WARNING: Unable to write quant rules: raster map <mytestrast> is integer
v.surf.bspline komplett.
(Mon Nov 10 20:26:54 2014) Befehl ausgeführt (3 Min 48 Sek)
could it be that the files aren't closed?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2434#comment:8&gt;
      Cpu: OSX/Intel |
Can you please re-run the test and watch how big the files grow in
Ticket URL: <http://trac.osgeo.org/grass/ticket/2434#comment:9&gt;
      Cpu: OSX/Intel |
I re-ran the test.
File 6684.0 was 20,788 KB and file 6684.1 was 361 KB. The others were 1
KB.
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/.tmp/unknown/6684.1'
to
Permission denied
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/.tmp/unknown/6684.0'
to
Permission denied
Ticket URL: <https://trac.osgeo.org/grass/ticket/2434#comment:10&gt;
Priority: major | Milestone: 7.0.1
Component: Raster | Version: svn-releasebranch70
      Cpu: OSX/Intel |
Changes (by annakrat):
  * priority: normal => major
  * version: svn-trunk => svn-releasebranch70
  * milestone: 7.0.0 => 7.0.1
Comment:
How to reproduce (taken from #2597):
g.region rast=elevation res=100
v.random out=points n=1000 -z zmax=100
v.surf.bspline in=points raster_o=surf ns=100 ew=100
Ticket URL: <http://trac.osgeo.org/grass/ticket/2434#comment:11&gt;
      Cpu: OSX/Intel |
Comment(by annakrat):
Anyone has any idea? I looked at it but without the ability to debug on
Windows I couldn't find anything.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2434#comment:12&gt;
#2434: v.surf.bspline: WARNING: Unable to rename null file / WARNING: Unable to
write quant rules:
Resolution: | Keywords: v.surf.bspline
       CPU: OSX/Intel | Platform: MSWindows 8
Ticket URL: <https://trac.osgeo.org/grass/ticket/2434#comment:13&gt;
write quant rules:
Comment (by hellik):
Replying to [comment:11 annakrat]:
tested here with
System Info
GRASS SVN revision: 65777
Build date: 2015-07-25
Build platform: i686-pc-mingw32
GDAL: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
and the example from the manual
g.region -p region=rural_1m@PERMANENT res=2
raster_output=elev_lid792_rast ew_step=5 ns_step=5 method=bicubic
lambda_i=0.1 memory=900
Zellen für die Rasterkarte <elev_lid792_rast> werden interpoliert.
Adjusted EW splines 121
Adjusted NS splines 131
Processing subregion 1 of 4...
16805 points found in this subregion
Processing subregion 2 of 4...
13741 points found in this subregion
Processing subregion 3 of 4...
13512 points found in this subregion
Processing subregion 4 of 4...
11564 points found in this subregion
Schreibe Ausgabe...
'J:\gisdata\nc_spm_08_grass7\user1\.tmp/unknown\5848.1' to
'J:\gisdata\nc_spm_08_grass7\user1\cell_misc\elev_lid792_rast\null':
Permission denied
'J:\gisdata\nc_spm_08_grass7\user1\.tmp/unknown\5848.0' to
'J:\gisdata\nc_spm_08_grass7\user1\fcell\elev_lid792_rast': Permission
denied
WARNING: Unable to write quant rules: raster map <elev_lid792_rast> is
integer
(Sun Jul 26 10:30:40 2015) Befehl ausgeführt (38 Sek)
bug report still valid.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2434#comment:14&gt;
write quant rules:
Resolution: | Keywords: v.surf.bspline, raster, quant
                         | rules, null file, cell file
Changes (by hellik):
* keywords: v.surf.bspline => v.surf.bspline, raster, quant rules, null
     file, cell file
Ticket URL: <https://trac.osgeo.org/grass/ticket/2434#comment:15&gt;
