GDAL
September 28, 2014, 9:34pm
1
#2436: v.out.postgis: Unsupported geometry type / Unable to write feature in
vector map
Reporter: martin | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: svn-trunk
Keywords: v.out.postgis | Platform: Linux
Cpu: x86-64 |
This package:
http://foxtrot.mgras.net/static/newcs_correct_collect.tbz
contains a packed vector map plus a little text file.
The top of the text file shows two commands to export the vector map into
PostGIS (PostGIS geometry, no topology). The "v.out.ogr" works as
promised but the "v.out.postgis" doesn't .... and the bottom part of the
text file contains the corresponding debug output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2436> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
September 29, 2014, 1:00pm
2
vector map
Cpu: x86-64 |
Comment(by martin):
Mapset <nlcd2011error> in Location <wgs84>[[BR]]
GRASS 7.1.svn > gdb --args v.out.postgis input=newcs_correct_collect
type=area olayer=newcs_correct_pg_collect dsn="PG:host=localhost
dbname=landcover user=martin" options="FID=ogc_fid,
GEOMETRY_NAME=wkb_geometry, SPATIAL_INDEX=YES, PRIMARY_KEY=YES, SRID=4326"
--verbose[[BR]]
[...][[BR]]
Reading symbols from
/opt/GRASS7/grass-7.1.svn/bin/v.out.postgis...done.[[BR]]
(gdb) r[[BR]]
Starting program: /opt/GRASS7/grass-7.1.svn/bin/v.out.postgis
input=newcs_correct_collect type=area olayer=newcs_correct_pg_collect
dsn=PG:host=localhost\ dbname=landcover\ user=martin options=FID=ogc_fid,\
GEOMETRY_NAME=wkb_geometry,\ SPATIAL_INDEX=YES,\ PRIMARY_KEY=YES,\
SRID=4326 --verbose[[BR]]
warning: no loadable sections found in added symbol-file system-supplied
DSO at 0x7ffff7ffa000[[BR]]
[Thread debugging using libthread_db enabled][[BR]]
Using host libthread_db library "/lib/x86_64-linux-
gnu/libthread_db.so.1".[[BR]]
No database connection for layer <1>[[BR]]
Using PostGIS format[[BR]]
WARNUNG: Unsupported geometry type (64)[[BR]]
WARNUNG: Unable to write feature in vector map
<newcs_correct_pg_collect>[[BR]]
FEHLER: Feature type 64 is not supported[[BR]]
NOTICE: table "newcs_correct_pg_collect" does not exist, skipping[[BR]]
KONTEXT: SQL statement "DROP TABLE IF EXISTS
public.newcs_correct_pg_collect RESTRICT"[[BR]]
PL/pgSQL function dropgeometrytable(character varying,character
varying,character varying) line 15 at EXECUTE statement[[BR]]
[Inferior 1 (process 7881) exited with code 01][[BR]]
Ticket URL: <https://trac.osgeo.org/grass/ticket/2436#comment:1> ;
GDAL
October 22, 2014, 3:18pm
3
vector map
Reporter: martin | Owner: martinl
Type: defect | Status: assigned
Cpu: x86-64 |
Changes (by martinl):
* cc: grass-dev@… (added)
* owner: grass-dev@… => martinl
* status: new => assigned
* milestone: => 7.0.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/2436#comment:2> ;
GDAL
October 22, 2014, 4:03pm
4
vector map
Cpu: x86-64 |
Comment(by martinl):
Please could you try r62360 (trunk)?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2436#comment:3> ;
GDAL
October 22, 2014, 8:27pm
5
vector map
Type: defect | Status: closed
Resolution: fixed | Keywords: v.out.postgis
Platform: Linux | Cpu: x86-64
Changes (by martin):
* status: assigned => closed
* resolution: => fixed
Comment:
Did that - and it works as expected/promised/before. Great !
Ticket URL: <http://trac.osgeo.org/grass/ticket/2436#comment:4> ;
