[GRASS-dev] [GRASS GIS] #2442: np.float128 does not always exist
Reporter: jradinger | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: svn-trunk
Keywords: | Platform: Unspecified
      Cpu: x86-32 |
When compiling the latest SVN (62197) of GRASS7 trunk I run into following
error (first among the error list, mostly in the temporal dir):
   File "/usr/local/src/grass7_trunk/dist.i686-pc-linux-
gnu/scripts/t.vect.univar", line 66, in <module>
     import grass.temporal as tgis
gnu/etc/python/grass/temporal/__init__.py", line 29, in <module>
     from temporal_vector_algebra import *
gnu/etc/python/grass/temporal/temporal_vector_algebra.py", line 420, in
<module>
     import grass.pygrass.modules as pygrass
gnu/etc/python/grass/pygrass/__init__.py", line 15, in <module>
     from . import raster
gnu/etc/python/grass/pygrass/raster/__init__.py", line 35, in <module>
     from grass.pygrass.raster.buffer import Buffer
gnu/etc/python/grass/pygrass/raster/buffer.py", line 14, in <module>
     DCELL = (np.float64, np.float128)
AttributeError: 'module' object has no attribute 'float128'
make[1]: *** [t.vect.univar.tmp.html] Error 1
Here I am running Python 2.7.3 with numpy 1.9.0.
Here [http://stackoverflow.com/questions/9062562/what-is-the-internal-
precision-of-numpy-float128] it says that is is related to the
architecture. In my case I am on a 32 bit system.
Changing from np.float128() to np.longdouble() (which exists on my system)
should solve the problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2442&gt;
Priority: normal | Milestone: 7.1.0
Component: Python | Version: svn-trunk
      Cpu: x86-32 |
Changes (by martinl):
  * component: Default => Python
  * milestone: => 7.1.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/2442#comment:1&gt;
      Cpu: x86-32 |
Comment(by zarch):
Right, I didn't thought about it!
Now should be fix in r62206.
Moreover I've disconnected (r62205) and isolate the ctypes part of pygrass
from the rest, this should make the whole pygrass more stable (I hope).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2442#comment:2&gt;
