#2445: r.mask -r removal not working in GRASS 7.1 svn r.62210
Reporter: baharmon | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.mask
CPU: Unspecified | Platform: MSWindows 8
Comment (by mlennert):
Could anyone test this on Windows, i.e. create a raster file named mask
(lowercase) and then attempt 'g.remove type=rast pattern=MASK -f' and
'g.remove -i type=rast pattern=MASK' ?
And if the first doesn't work, but the second does could the following
lines in r.mask:
grass.run_command('g.remove', flags='f', quiet=True,
type='raster', name='MASK')
be replaced by
grass.run_command('g.remove', flags='fi', quiet=True,
if we are in Windows ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2445#comment:9>
