#2448: Fontconfig error with cairo on Windows
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: Display | Version: 7.0.0
Resolution: | Keywords: font, text, legend, scale bar
CPU: Unspecified | Platform: MSWindows 8
Comment (by annakrat):
Replying to [comment:44 hellik]:
> Replying to [comment:42 annakrat]:
> > Unfortunately, no change. I wonder if the problem is something
different then permissions.
> I'm quite sure that it is a file writing permission issue in a usually
non-writeable folder (c:\Program Files\your program\folder to change
something) in win 8 and above.
> tested it on several win 7 boxes here, it works fine. unfortunately no
win 8 oder win 10 box here on my side.
If you want to spend even more time on it, you can download/use windows 10
for free, and run it in virtual box. But it is not just windows 10 issue
from what I've seen.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2448#comment:47>
