#2448: Fontconfig error with cairo on Windows
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: Display | Version: 7.0.0
Resolution: | Keywords: font, text, legend, scale bar
CPU: Unspecified | Platform: MSWindows 8
Comment (by hellik):
Replying to [comment:61 annakrat]:
> > > where should I see this log? I still can't see any text in the
legend...
> Oh I see. Yes I can see there the 2 oks.
> > some special security rules? antivirus sw? virtual windows or real
windows box?
> I am running windows 10 in a virtual machine, I didn't do anything
special, I haven't installed any antivirus software. Sorry, I know it's
frustrating...
for the record the conversation on the nsis forum:
http://forums.winamp.com/showthread.php?t=382427
I've tested the modified installer now on following win boxes with
different locales:
win Vista 32bit
win 7 32bit and 64bit
win 8.1 64bit
it works nicely there, so no idea here from my side at the moment what is
going on ...
from the nsis forum:
I don't think .bat files support manifests but if the parent process is
elevated then the .bat file should be elevated as well.
I assume you have verified the permissions on the security tab in the
properties for the files/folders in question on the systems it fails on?
If it works on some systems and not on others you should probably move
your investigation to g.mkfontcap.exe...
can you look at the permissions of the $installdir/etc folder and the
fontcap file by right click on folder/file -> properties -> security tab?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2448#comment:62>
