[GRASS-dev] [GRASS GIS] #2454: wxgui: list of db columns only becomes available after entering layer number by hand
number by hand
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: unspecified
Keywords: columns list | Platform: Linux
      Cpu: Unspecified |
* Load a vector map with attribute table
  * In the d.vect dialogue go to the Labels section
  * Click on the widget for the list of attribute columns
=> empty (in trunk) or you cannot even open the list (grass64release)
  * Go into the layer number text field, erase the layer number (1) and
write the same layer number (1)
=> list is filled with available columns
You can also go into the Selection section and select first -1 as layer
number, then back to 1.
This is on Debian testing with wx 2.8.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2454&gt;
number by hand
      Cpu: Unspecified |
Comment(by annakrat):
Weird, I have no problem, I can see the columns (latest trunk and release
branch, Ubuntu, wxPython 2.8). Anyone else can test?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2454#comment:1&gt;
number by hand
      Cpu: Unspecified |
Could you try r63173? I tried to fix this problem for wxPython 3. But I
didn't have the problem for 2.8, so I still don't know why it's not
working for you.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2454#comment:2&gt;
number by hand
      Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:2 annakrat]:
working for you.
This commit seems to have a bad effect in 2.8. When I try to add raster
map from GUI, the `d.rast` doesn't react when you choose raster map from
the selection widget.
>>> wx.version()
'2.8.12.1 (gtk2-unicode)'
Can anybody confirm it? Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/2454#comment:3&gt;
number by hand
      Cpu: Unspecified |
Replying to [comment:3 martinl]:
I didn't have the problem for 2.8, so I still don't know why it's not
working for you.
> >>> wx.version()
Thanks, it should be fixed in r63199.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2454#comment:4&gt;
number by hand
      Cpu: Unspecified |
Replying to [comment:4 annakrat]:
confirmed. Thanks for quick fix!
Ticket URL: <http://trac.osgeo.org/grass/ticket/2454#comment:5&gt;
number by hand
      Type: defect | Status: closed
Resolution: fixed | Keywords: columns list
  Platform: Linux | Cpu: Unspecified
Changes (by mlennert):
  * status: new => closed
  * resolution: => fixed
Comment:
Works perfectly for me now as well. Thanks a lot !
Closing this ticket.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2454#comment:6&gt;
