[GRASS-dev] [GRASS GIS] #2456: read CSV from GDAL data directory
  Reporter: martinl | Owner: grass-dev@…
      Type: task | Status: new
  Priority: blocker | Milestone: 7.0.5
Component: Projections/Datums | Version: svn-releasebranch70
Resolution: | Keywords: gdal, g.proj
Comment (by neteler):
After discussion with Even Rouault at the FOSS4G 2016 code sprint and some
testing with m.proj
  * removal of local copies of NAD and datum shift files which are indeed
used from GDAL
  * extended documentation in lib/proj/README.txt
Done in r69211.
After extensive testing backport candidate. Test values available in
https://github.com/OSGeo/proj.4/tree/master/nad . Test cases should be
implemented with m.proj.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2456#comment:33&gt;
