[GRASS-dev] [GRASS GIS] #2456: read CSV from GDAL data directory
  Reporter: martinl | Owner: grass-dev@…
      Type: task | Status: new
  Priority: blocker | Milestone: 7.4.0
Component: Projections/Datums | Version: svn-releasebranch70
Resolution: | Keywords: gdal, g.proj
Comment (by martinl):
Replying to [comment:37 neteler]:
> Furthermore the g.proj code needs updates. Or in lib/proj/?
> For some tests, see
> https://lists.osgeo.org/pipermail/grass-user/2016-September/075035.html
what is exact problem? I tried in G72 and G73
g.proj -t epsg=2992 datumtrans=-1
Both version gives me the same output:
1
Used in whole nad83 region
towgs84=0.000,0.000,0.000
Default 3-Parameter Transformation (May not be optimum for older datums;
use this only if no more appropriate options are available.)
2
Used in Florida
nadgrids=FL
Transforms 'Old NAD83' to 'HPGN NAD83'
3
Used in Maryland
nadgrids=MD
4
Used in Tennessee
nadgrids=TN
5
Used in Wisconsin
nadgrids=WI
6
Used in Washington - Oregon
nadgrids=WO
BTW, instead of
grass72 -c epsg:2992 ~/grassdata/oregon2992_nad83_WO --exec g.proj -t
epsg=2992 datumtrans=6 -p
you can do
grass72 -c epsg:2992:6 ~/grassdata/oregon2992_nad83_WO --exec g.proj -p
The same approach works also in G73.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2456#comment:38&gt;
