[GRASS-dev] [GRASS GIS] #246: can't overwrite vector map if it's name is fully qualified (i.e. contains @mapset)
@mapset)
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
GRASS can't overwrite a vector map output if the output name is given with
@mapset. This is not strictly a wxGUI issue, but as wxGUI uses a fully
qulified name for output, it manifests itself there. Examples:
C module:
v.random out=tmp@PERMANENT n=1 --o
Illegal filename. Character <@> not allowed.
ERROR: <tmp@PERMANENT> is an illegal file name
Shell script:
v.in.geonames in=PL.txt out=tmp@PERMANENT --o
WARNING: Vector map <tmp@PERMANENT> already exists and will be
          overwritten
WARNING: Unable to open directory
          '/home/grassdata/wgs84/PERMANENT/vector/tmp@PERMANENT'
ERROR: Unable to delete vector map <tmp@PERMANENT>
Note that for raster it works:
v.to.rast in=tmp out=tmp@PERMANENT use=cat --o
Converted areas: 0 of 0
Converted points/lines: 1 of 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/246&gt;
@mapset)
Resolution: | Keywords:
  Platform: All | Cpu: All
Comment (by glynn):
Replying to [ticket:246 msieczka]:
with @mapset. This is not strictly a wxGUI issue, but as wxGUI uses a
fully qulified name for output, it manifests itself there. Examples:
> {{{ v.random out=tmp@PERMANENT n=1 --o }}}
> [[BR]]
> {{{ Illegal filename. Character <@> not allowed. }}}
This is a bug in v.random. However, Vect_open_new() didn't allow fully
qualified names. Both are fixed in SVN trunk.
Ticket URL: <http://trac.osgeo.org/grass/ticket/246#comment:1&gt;
@mapset)
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by martinl):
  * status: new => closed
  * resolution: => fixed
Comment:
Already backported to devbr6, closing the ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/246#comment:2&gt;
