#2462: reStructuredText files generated by Sphinx shows in svn status
Reporter: wenzeslaus | Owner: grass-dev@…
Type: task | Status: new
Priority: trivial | Milestone: 7.0.0
Component: Docs | Version: svn-trunk
Keywords: sphinx, sphinx-apidoc, svn, versioning, documentation, rst | Platform: All
Cpu: Unspecified |
When I build documentation (`make sphinxdoc`) and then do `svn status` I
get a lot of `rst` files which were generated by Sphinx during the build.
The affected directories are:
* `gui/wxpython/docs/wxgui_sphinx/src`
* `lib/python/docs/src/`
Just ignoring the files in SVN is probably not a good option since the
list of files may (will) grow. Perhaps mixing the generated and hand-
written files in one directory is bad. Do you have any ideas how to solve
this?
The workaround is to do `make cleansphinx` which will delete the generated
`rst` files. I still see `gui/wxpython/docs/wxgui_sphinx/_build` although
I don't see `_build` in `lib/python...` directory.
Related: #1465
Ticket URL: <http://trac.osgeo.org/grass/ticket/2462>
