[GRASS-dev] [GRASS GIS] #2472: v.in.lidar gives negative point count on large las files
Reporter: dnewcomb | Owner: grass-dev@…
     Type: defect | Status: new
Component: Default | Version: svn-releasebranch70
Keywords: v.in.lidar point initial count | Platform: Unspecified
      Cpu: x86-64 |
Trying to use v.in.lidar to import points from an las file with 3531181701
points
v.in.lidar -o -b input=/gisdata/grass7/lidardir/big_lidar_file_ground.laz
output=whole_co_ground_pts
Over-riding projection check
Importing -763785595 points..
Seems to be importing so far..
Running GRASS 7.0 SVN snapshot from 10/25/14
Ticket URL: <https://trac.osgeo.org/grass/ticket/2472&gt;
      Cpu: x86-64 |
Comment(by dnewcomb):
v.in.lidar has been running now for 10 hours and is using 13 GB of RAM for
this instance. Write access to the sqlite database by other vector
operations is currently blocked.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2472#comment:1&gt;
      Cpu: x86-64 |
Comment(by mlennert):
Replying to [ticket:2472 dnewcomb]:
3531181701 points
> v.in.lidar -o -b
A sign of integer overflow. AFAICT, in this particular case this is just
in the message where a '%d' placeholder is used which represents a signed
int. But the count of the number of points is defined as unsigned int and
with larger files this will probably also overflow.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2472#comment:2&gt;
      Cpu: x86-64 |
Replying to [comment:1 dnewcomb]:
for this instance. Write access to the sqlite database by other vector
Try importing with the -t flag to not create an attribute table. Or
possibly use PostgreSQL as a back end for the attributes.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2472#comment:3&gt;
