#2473: v.net connection operation
Reporter: matmar | Owner: grass-dev@…
Component: Vector | Version: svn-trunk
Keywords: v.net | Platform: Linux
Cpu: Unspecified |
I'm not able to connect points with the nearest line segment in a line
vector using v.net.
v.net connects a line vector with the points in a point vector file. The
connection process follows the category progress so the output is not the
fittest solution for a network distance analysis as the one I need to
perform.
Following, the commands to reproduce the issue in nc_spm_08_grass7:
Replying to [ticket:2473 matmar]:
> Hi all,
vector using v.net.
perform.
> g.region vect=roadsmajor
> v.mkgrid map=points_grid -p position=region grid=20,20
> v.net input=roadsmajor points=points_grid out=roads_to_points
operation=connect threshold=5000 --o
> plot:
> d.mon wx0
> d.vect roads_to_points
> d.vect points_grid col=red display=cat
> Is there a way to connect each point to the nearest original road
segment?
Use the '-s' flag (Snap points to network) available in grass7.
Replying to [comment:1 mlennert]:
> > Hi all,
vector using v.net.
The connection process follows the category progress so the output is not
the fittest solution for a network distance analysis as the one I need to
perform.
> > plot:
> > d.mon wx0
segment?
> Moritz
Hi Moritz,
-s glues points to the nearest network segment but doesn't connect each
point to the nearest network segment (so I lose information). I attached a
drawing about what I meant, hoping it helps.
> Hi all,
vector using v.net.
perform.
This is a bug in v.net, fixed in r62683,4 (trunk, relbr7).
