[GRASS-dev] [GRASS GIS] #2474: G7: vector network toolbox crash
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Component: Vector | Version: svn-releasebranch70
Keywords: v.net | Platform: Unspecified
      Cpu: Unspecified |
(copied here from trac comment:27:ticket:2326)
The vector network toolbox seems to lack some related update (trunk from
4th of Nov 2014). We tried to run v.net.alloc therein on roads_major:
   File "/home/matteo/software/grass_trunk/dist.x86_64
-unknown-linux-gnu/gui/wxpython/lmgr/frame.py", line 788, in
OnVNet
self.GetMapDisplay().OnVNet(event)
-unknown-linux-gnu/gui/wxpython/mapdisp/frame.py", line
1420, in OnVNet
self.dialogs['vnet'] = VNETDialog(parent=self,
giface=self._giface)
-unknown-linux-gnu/gui/wxpython/vnet/dialogs.py", line 134,
in __init__
self._createInputDbMgrPage()
-unknown-linux-gnu/gui/wxpython/vnet/dialogs.py", line 448,
in _createInputDbMgrPage
self.inpDbMgrData['dbMgr'] = DbMgrBase()
-unknown-linux-gnu/gui/wxpython/dbmgr/base.py", line 669, in
__init__
self.dbMgrData['mapDBInfo'] =
VectorDBInfo(self.dbMgrData['vectName'])
-unknown-linux-gnu/gui/wxpython/dbmgr/vinfo.py", line 74, in
__init__
VectorDBInfoBase.__init__(self, map)
-unknown-linux-gnu/gui/wxpython/gui_core/gselect.py", line
723, in __init__
if not self._CheckDBConnection(): # -> self.layers
731, in _CheckDBConnection
self.layers = grass.vector_db(map = self.map, stderr =
nuldev)
-unknown-linux-gnu/etc/python/grass/script/vector.py", line
42, in vector_db
**args)
-unknown-linux-gnu/etc/python/grass/script/core.py", line
420, in read_command
returncode=returncode)
grass.exceptions
CalledModuleError
Module run None v.db.connect --q -g stderr=<open file
'/dev/null', mode 'w+' at 0x7ffac45d8f60> sep=; ended with
error
Process ended with non-zero return code 1. See errors in the
(error) output.
A workaround has been submitted in r62614 as of trac trac
comment:28:ticket:2326
Ticket URL: <http://trac.osgeo.org/grass/ticket/2474&gt;
      Cpu: Unspecified |
Comment(by wenzeslaus):
To clarify, r62614 is the fix for the traceback and allows the tool to
work, so you will not get this traceback anymore. The
comment:28:ticket:2326 notes the unpleasant true about most of the GUI
code, refactoring is needed and better (and explicit) error handling must
be introduced. So milestone of this would be 8.0.0 in my opinion.
In comment:29:ticket:2326, I was talking about other potential errors.
Sorry for confusion.
I'm suggesting to close this as fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2474#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.net
  Platform: Unspecified | Cpu: Unspecified
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Comment:
I changed again the exception handling in r62691. This can be closed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2474#comment:2&gt;
Resolution: fixed | Keywords: v.net, gselect
Changes (by wenzeslaus):
  * keywords: v.net => v.net, gselect
Comment:
Backported to release 70 in r62789.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2474#comment:3&gt;
