Thanks for the report and for testing OSGeo4W 64bit. Please provide also
the error message and if possible, try that with GRASS NC sample location,
so that developers can try to reproduce it eventually.
If you know how, it might be actually useful to try some GDAL directly, to
see where the issue actually is.
I tried that with GRASS NC sample data. And I've uploaded the error
message(in japanese sorry). the message means that "r.out.gdal has stopped
working. A problem caused the program to stop working correctly. Windows
will close the program and notify you if a solution is available"
Gdal commands works correctry on OSGeo4W 64bit. But I didn't try reading
GRASS data with gdal directry so gdal on OSGeo4W doesn't support GRASS
format.
thanks
to see where the issue actually is.
