#248: v.info vs. r.info: different region output formats
Reporter: sebastianh | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 7.0.0
Component: default | Version: unspecified
Keywords: v.info, r.info, region output | Platform: All
Cpu: All |
In a location with a geographic crs, the region outputs (esp. the unit
formats) of vector and raster layers differs from each other.
v.info prints the region in decimal degrees (DD) whereas r.info produces
an output in degrees,minutes,seconds (DMS).
For example (nc_ll location from www.grassbooks.org):
> v.info -g precip_30ynormals
north=36.49917
south=33.99472
east=-75.62194
west=-84.02389
top=1615.440000
bottom=2.438400
> r.info -g elev_ned_03arcsec
north=35:54:40.666666N
south=35:35:17.334885N
east=78:27:08.335106W
west=78:49:17.333333W
For parsing both ouputs with external tools, it would be better if the
formats were equal (preferably decimal degrees).
Resolution: | Keywords: v.info, r.info, region output
Platform: All | Cpu: All
Comment (by martinl):
BTW in GRASS7 I would like to add shell script style output for r/v.info.
To follow standard flag naming, this flag should '-g' which is now
reserved for "Print map region only" (which could be renamed to '-r'.) ?
Comment (by glynn):
Replying to [ticket:248 sebastianh]:
Done (also for !r3.info). In r34118, -g now always outputs in decimal.
Comment (by hamish):
Replying to [comment:2 martinl]:
> r/v.info.
? don't we already have that in GRASS 6.x from lots of flags?
> now reserved for "Print map region only" (which could be
> renamed to '-r'.) ?
-g is used across modules more generally to mean "output in shell script
style"; albeit usually (but not always) to do with region bounds. (eg
r.univar)
As '-r' works quite nicely for "range" (IMO) I don't see the need for a
change. As long as we are consistent it is quickly learned.
