[GRASS-dev] [GRASS GIS] #2480: v.class.ml: ImportError: No module named training_extraction
  Reporter: mlennert | Owner: grass-dev@…
      Type: defect | Status: new
Component: Addons | Version: svn-releasebranch70
Resolution: | Keywords: v.class.ml g.extension
Comment (by lrntct):
Replying to [comment:15 martinl]:
> Replying to [comment:14 lrntct]:
> > I tried with build r68156 and still have the same error:
> are you sure that you don't have any local changes in the source code,
any conflicts? Please remove `~.grass7/addons` dir and try again.
> I am not able to reproduce it even with `grass-daily` package or self-
compiled relbr70.
I haven't done any change to the source code. Just tried to install it
because I have similar issues with other python modules containing various
files (cf. #2968).
I did remove `~.grass7/addons` and the installation of v.class.ml worked.
But it might worth investigating because a similar issue is still
happening with other modules (cf. #2968).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2480#comment:16&gt;
