#2482: g.gui.iclass: temp maps are not erased when tool is closed
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Component: wxGUI | Version: svn-releasebranch70
Keywords: g.gui.iclass temporary maps | Platform: Unspecified
Cpu: Unspecified |
After several runs of g.gui.iclass, each time closing the tool as by
clicking the "Close" button, my mapset is now cluttered with the
temporary maps created by the tool:
> g.list rast -p
raster fichiers disponibles dans le jeu de données <classif_par_objet> :
bati_15039.1 class_3_15039.2 seg_pan test_maxlik
bati_15961.1 class_4_15039.3 sol_nu_15039.0
veg_basse_15039.1
bati_15961.2 class_5_15039.4 sol_nu_15961.0
veg_basse_15961.1
class_1_15039.0 eau_15039.0 sol_nu_15961.1
veg_haute_15039.0
class_2_15039.1 eau_15961.0 test
veg_haute_15961.0
Apparently the clean up procedures do not work correctly.
Type: defect | Status: closed
Resolution: fixed | Keywords: g.gui.iclass temporary maps
Platform: Unspecified | Cpu: Unspecified
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:2 annakrat]:
> Any update on this one?
Sorry, this a bit off my radar. Now, once I quit the tool the temp maps
are erased. It can still be a bit odd to see these temp maps in your
mapset while you're working on the creation of training areas (to me at
least it sometimes happens that I need to go back to the normal layer
manager and map display (or to the command line) while I'm digitizing and
then I suddenly have all these temps maps in my map list), but I don't
know if this is avoidable and if they are erased after leaving the tool as
is the case now, I can live with that.
