#2485: v.segment: add options for a fixed distance (enhacement)
Reporter: hellik | Owner: grass-dev@…
Priority: major | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Keywords: v.segment | Platform: Unspecified
Cpu: Unspecified |
Comment(by hellik):
Replying to [ticket:2485 hellik]:
> v.segment - Creates points/segments from input vector lines and
positions.
> v.segment with an option for a fixed distance for points/segments (e.g.
every 100m) would be nice.
> the last segment may be shorter than the fixed distance.
to explain it a bit more: at the moment you can define points/segments by
stdin input or a text file; that's nice.
the enhancement (two options: point or line, fixed distance) would be so
that no stdin or a text file input is needed.
Cpu: Unspecified |
Comment(by hellik):
positions.
as a workaround for points I've added a little addon:
Cpu: Unspecified |
Comment(by pvanbosgeo):
Somebody must have read my mind.. I was just trying to figure out how to
do this.v.to.points.
I only need points along straight lines, so using v.to.points (with
use=vertex and dmax option set to a distance) seems to work too, although
the results are slightly off from those created by the
v.fixed.segmentpoints.
Resolution: | Keywords: v.segment
Comment (by mlennert):
Replying to [comment:3 hellik]:
positions.
(e.g. every 100m) would be nice.
by stdin input or a text file; that's nice.
I just posted in #2231 a diff to v.split that implements a flag allowing
to split lines according to a fixed distance. Combining this with
v.to.points use=node should give you the points as well.
