#2486: add parameter for transformation of input data to v.in.ogr/r.in.gdal
Reporter: jachym | Owner: grass-dev@…
Priority: normal | Milestone: 7.1.0
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
currently, you can not import vector or raster data, if their projection
is different from your location's projection.
Adding parameter (e.g. -T for 'transform') would allow users to import
data to target location and reproject them on the fly
adding another parameter (e.g. srs= ) could overwrite source file
projection (or set, in case of unknown)
this would enable us to import data, without former reprojection (but you
can not reproject postgis table easily) or without need for creating
temporary location just because you want to import data to grass
