GDAL
November 19, 2014, 9:55pm
1
#2496: r.random.surface error from RAN C library
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Component: Raster | Version: svn-trunk
Keywords: r.random.surface | Platform: MacOSX
Cpu: Unspecified |
We just encountered a weird bug in r.random.surface. So far, it seems to
showing up on the Mac intermittently but not on Linux. The message is...
ERROR: RAN1: j==-67 shouldn't happen
It was generated from a Python script that called r.random.surface in the
following way:
grass.run_command("r.random.surface", quiet = "True", output =
tempimpactg, distance = grazespatial, exponent = grazepatchy, high =
maxgrazeimpact)
I'm running on an oldish (ca. 5 years) iMac but with the latest OS X
10.9,x (no upgrade to 10.10 yet). This happens on both GRASS 7.0 beta3 and
7.1, both compiled 11 August 2014.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
November 20, 2014, 2:30am
2
Cpu: Unspecified |
Comment(by annakrat):
It comes from r.random.surface/random.c ran1 function, perhaps the new
random functions could be used instead?
http://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/lrand48.c
This applies also to r.random.cells. See also discussion
[http://lists.osgeo.org/pipermail/grass-dev/2014-July/070163.html here].
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:1> ;
GDAL
November 20, 2014, 2:33am
3
Cpu: Unspecified |
Comment(by cmbarton):
I don't know. But this bug causes our modeling script to crash so that we
get no results.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:2> ;
GDAL
November 20, 2014, 9:00pm
4
Cpu: Unspecified |
Comment(by glynn):
That appears to be a conversion of
[http://burro.astr.cwru.edu/Academics/Astr327/HW/HW2/ran1.f this Fortran
function].
That's supposed to generate uniform random numbers in the [0,1) interval,
and so can be replaced by G_drand48().
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:3> ;
GDAL
November 20, 2014, 9:11pm
5
Cpu: Unspecified |
If this is an easy fix, can someone let us know when it gets fixed? We
need this for landscape modeling experiments we are trying to run.
thanks
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:4> ;
GDAL
November 21, 2014, 1:53am
6
Cpu: Unspecified |
Replying to [comment:4 cmbarton]:
It would be most welcome if somebody from your group would submit a patch
which can be reviewed and eventually submitted.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:5> ;
GDAL
November 21, 2014, 2:55am
7
Cpu: Unspecified |
Unfortunately, no one here is a C programmer. We do Python, Java, and
other things. But not C.
Otherwise we might have figured it out and fixed it already.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:6> ;
Cpu: Unspecified |
Michael
Well, Python and Java are C-based languages:
http://en.wikipedia.org/wiki/List_of_C-based_programming_languages
I am merely trying to suggest that since you know what is wrong and how to
fix it, it probably won't be a big problem for anyone in your group who is
able to program in any language and able to compile grass. Of course, some
other grass developer could fix it faster, but from my experience, it's
better to try to fix things on your own if you need them to be fixed soon
enough, especially if the bug is not bothering other developers at that
time.
grass-dev mailing list
grass-dev@lists.osgeo.org
GDAL
November 21, 2014, 6:06pm
9
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:3 glynn]:
Can someone test attachment:r.random.surface.patch ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:7> ;
GDAL
November 21, 2014, 6:29pm
10
Cpu: Unspecified |
Is it updated in trunk or 7.1 dev? I can recompile and test.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:8> ;
GDAL
November 21, 2014, 6:40pm
11
Cpu: Unspecified |
Replying to [comment:8 cmbarton]:
> Michael
Sorry. I see it is a patch. I will try with 7.0 and let you know.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:9> ;
GDAL
November 24, 2014, 11:56pm
12
Cpu: Unspecified |
This patch seems to fix the problem. I'll know for sure after our script
repeated enough times. Most of the times, r.random.surface failed on the
first or second time run. Once it did not fail until the 62nd iteration.
I'm up to 65 iterations with no errors yet. So it looks good.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:10> ;
GDAL
December 2, 2014, 3:59pm
13
Cpu: Unspecified |
Comment(by neteler):
Will you submit the patch?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:11> ;
GDAL
December 2, 2014, 4:50pm
14
Cpu: Unspecified |
I tested this with trunk. While I can do the mechanics of submitting this
later this week for 7.0 and trunk, I'm a little hesitant since I'm not
familiar with C and don't know if this should be applied to other
r.random.x modules or not.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:12> ;
GDAL
December 2, 2014, 5:14pm
15
Cpu: Unspecified |
Indeed, these files are 99% cloned:
* r.random.cells/gasdev.c
* r.random.surface/gasdev.c
and
* r.random.cells/random.c
* r.random.surface/random.c
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:13> ;
GDAL
December 4, 2014, 5:29pm
16
Cpu: Unspecified |
So multiple patches are needed for different modules? Different for GRASS
7.0 and 7.1 or the same?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:14> ;
GDAL
December 4, 2014, 5:48pm
17
Cpu: Unspecified |
Replying to [comment:14 cmbarton]:
GRASS 7.0 and 7.1 or the same?
The same patch will work in 7.0 and 7.1.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:15> ;
GDAL
December 4, 2014, 5:55pm
18
Cpu: Unspecified |
So just a patch for each module that uses this then.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2496#comment:16> ;
