#2498: yet another problem with GUI toolbox menu
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: menu tree xml | Platform: Unspecified
Cpu: OSX/Intel |
I just compiled from GRASS trunk. It compiles with the normal set of
errors in GUI modules using a windowing class created a year or two back.
Normally these do not have any impact on running. But it is again not
generating XML file needed for the toolbox menu, probably because it is
not finding wx again. Here is the error.
Also, I thought trunk is supposed to be GRASS 7.0. But it is showing up as
GRASS svn 7.1
Welcome to GRASS 7.1.svn (r62850M)
GRASS homepage: http://grass.osgeo.org
This version running through: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching <wxpython> GUI in the background, please wait...
GRASS 7.1.svn (Penaguila):~ > Traceback (most recent call last):
File
"/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py",
line 140, in <module>
sys.exit(main())
File
line 133, in main
app = GMApp(workspaceFile)
File
line 48, in __init__
wx.App.__init__(self, False)
File "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-
packages/wx-2.8-mac-unicode/wx/_core.py", line 7981, in __init__
self._BootstrapApp()
packages/wx-2.8-mac-unicode/wx/_core.py", line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File
line 82, in OnInit
workspace = self.workspaceFile)
File
"/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
line 119, in __init__
self._menuTreeBuilder = LayerManagerMenuData()
File
"/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/menudata.py",
line 40, in __init__
MenuTreeModelBuilder.__init__(self, filename,
expandAddons=expandAddons)
File
"/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/core/menutree.py",
line 64, in __init__
xmlTree = etree.parse(filename)
File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py",
line 1182, in parse
tree.parse(source, parser)
File
line 657, in parse
self._root = parser.close()
File
line 1654, in close
self._raiseerror(v)
File
line 1506, in _raiseerror
raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
Ticket URL: <http://trac.osgeo.org/grass/ticket/2498>
