#2499: GRASS70: v.in.ogr in does not handle "nan" in attribute tables properly
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: Vector | Version: unspecified
Resolution: | Keywords: v.in.ogr, DBMI, SQLite, nan
Comment (by alexbruy):
Seems still true with 7.8.2. For example, when I run v.net.centrality it
fails during saving results with the following message
Flattening the graph...
Graph was built
Computing degree centrality measure
Computing betweenness and/or closeness centrality measure
0..5..10..15..20..25..30..35..40..45..50..55..60..65..70..75..80..85..90..95..Computing
eigenvector centrality measure
Writing data into the table...
3..7..11..15..19..23..26..30..34..38..42..46..50..53..57..61..65..69..73..76..80..84..88..92..96..100
DBMI-SQLite driver error:
Error in sqlite3_prepare():
no such column: nan
no such column: nan
ERROR: Cannot insert new record: INSERT INTO
output748b41e8dcf84a96b7d78ba17246cc20
VALUES(27,0.100000,0.000000,30.000000,-nan)
Using network.shp from QGIS test dataset at
https://github.com/qgis/QGIS/tree/master/python/plugins/processing/tests/testdata/custom/grass7
Ticket URL: <https://trac.osgeo.org/grass/ticket/2499#comment:7>
