[GRASS-dev] [GRASS GIS] #2501: r.out.gdal -t creates offset values in raster table for integer grids with values beginning with 1
Reporter: dnewcomb | Owner: grass-dev@…
     Type: defect | Status: new
Component: Default | Version: svn-releasebranch70
Keywords: r.out.gdal table attribute alignment | Platform: Linux
      Cpu: x86-64 |
Exporting integer grids with values starting with 1 using r.out.gdal -t
results in a raster attribute table with vertically shifted values in the
last 3 columns.
For example, if you have a raster with values of 1 to 5 with associated
classes, you would expect a table that looks like this:
OID Value MIN MAX CLASS
1 1 1 1 flat
2 2 2 2 summit
3 3 3 3 ridge
4 4 4 4 shoulder
5 5 5 5 spur
( Should the OID start with 0?, not sure )
In the current version of the software, the output table looks like this:
0 0 1 1 flat
1 1 2 2 summit
2 2 3 3 ridge
3 3 4 4 shoulder
4 4 5 5 spur
5 5 0 0 ERROR
See http://lists.osgeo.org/pipermail/grass-dev/2014-November/072021.html,
The issue seems to be in lines 73 - 78 in r.out.gdal/attr.c:
         if (maptype == CELL_TYPE) {
           for (i = 0; i < cats.ncats; i++) {
             label = Rast_get_ith_c_cat(&cats, i, &CellMin, &CellMax);
                 GDALRATSetValueAsInt(hrat, i, 0, CellMin);
                 GDALRATSetValueAsInt(hrat, i, 1, CellMax);
                 GDALRATSetValueAsString(hrat, i, 2, label);
With this current ugly hack I've got has the values aligned with the
classes again, but there is an extra OID 0 line with 0 or blank values for
the fields at the beginning of the table.
           for (i = 0; i < cats.ncats-1; i++) {
                 GDALRATSetValueAsInt(hrat, i+1, 0, CellMin);
                 GDALRATSetValueAsInt(hrat, i+1, 1, CellMax);
                 GDALRATSetValueAsString(hrat, i+1, 2, label);
Sample output to this hack would be:
0 0 0 0
1 1 1 1 flat
2 2 2 2 summit
3 3 3 3 ridge
4 4 4 4 shoulder
5 5 5 5 spur
This does not look quite right.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2501&gt;
      Cpu: x86-64 |
Comment(by dnewcomb):
Sorry, example tables in a more readable format[[BR]]
Expected Table:[[BR]]
OID Value MIN MAX CLASS[[BR]]
1 1 1 1 flat [[BR]]
2 2 2 2 summit [[BR]]
3 3 3 3 ridge [[BR]]
4 4 4 4 shoulder [[BR]]
5 5 5 5 spur
[[BR]][[BR]]
Current table:[[BR]][[BR]]
OID Value MIN MAX CLASS [[BR]]
0 0 1 1 flat [[BR]]
1 1 2 2 summit [[BR]]
2 2 3 3 ridge [[BR]]
3 3 4 4 shoulder [[BR]]
4 4 5 5 spur [[BR]]
5 5 0 0 ERROR
[[BR]]
[[BR]]
Hacked table:[[BR]][[BR]]
0 0 0 0 [[BR]]
1 1 1 1 flat [[BR]]
5 5 5 5 spur
Ticket URL: <http://trac.osgeo.org/grass/ticket/2501#comment:1&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: r.out.gdal table attribute alignment
  Platform: Linux | Cpu: x86-64
Changes (by mmetz):
  * status: new => closed
  * resolution: => wontfix
Comment:
Replying to [ticket:2501 dnewcomb]:
last 3 columns.
In your example, the output is shifted in the first 2 columns. The last 3
columns are correct. What software did you use? The faulty fields `OID`
and `value` are added by this software.
Here is an example using the NC sample dataset:
g.region -p rast=landclass96
r.out.gdal in=landclass96 out=landclass96.tif -t
This creates a GeoTIFF with an associated file landclass96.tif.aux.xml
holding the attribute table. The fields and first entry of this attribute
table are
min, max, label
1, 1, developed
all fine.
According to `gdalinfo landclass96.tif`, the fields and first entry of
this attribute table are
min, max, label
1, 1, developed
all fine.
Exporting landclass96 in Erdas Imagine format (`format=HFA`), there is no
associated .xml file.
According to `gdalinfo landclass96.img`, the fields and first entry of
this attribute table are now
Red, Green, Blue, min, max, Class_Names
0, 0, 0, 0, 1, 1, developed
this is wrong, a bug in GDAL.
If GDAL itself is not able to correctly reproduce raster attribute tables
created by itself, other software does not really have a chance to read
raster attribute tables ay provided by GDAL. Further on, it seems that
some other software further modifies the raster attribute table:
It seems that raster attribute tables created by GDAL are not widely
supported, if yes, errors might be introduced.
Closing as wontfix because this is a problem of GDAL and GIS software
other than GRASS.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2501#comment:2&gt;
Software used to read the raster table was ArcGIS 10.2.2
Ticket URL: <http://trac.osgeo.org/grass/ticket/2501#comment:3&gt;
Replying to [comment:2 mmetz]:
-t results in a raster attribute table with vertically shifted values in
the last 3 columns.
3 columns are correct. What software did you use? The faulty fields `OID`
table are
> min, max, label
> 1, 1, developed
> all fine.
> min, max, label
> 1, 1, developed
> all fine.
no associated .xml file.
tables created by itself, other software does not really have a chance to
read raster attribute tables ay provided by GDAL. Further on, it seems
that some other software further modifies the raster attribute table:
other than GRASS.
I'll check with the gdal list.
BTW,I'm running GRASS 70 with gdal 1.11.1, and when I run r.out.gdal -t, I
get associated .xml files with both .tif and .img formats.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2501#comment:4&gt;
