[GRASS-dev] [GRASS GIS] #2505: v.build.polylines options aren't working
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Keywords: v.build.polylines | Platform: All
      Cpu: Unspecified |
from the user ML
http://lists.osgeo.org/pipermail/grass-user/2014-December/071385.html
>But I’ve tried using cat=first and it continues to assign multiple cats
to
the segments.
tested here on my side.
from the manual:
     cats=no - No category number is assigned to a polyline. Also
attributes
tables linked to the input vector map are not copied to the output vector
map.
     cats=first - Assign to a polyline category number of the first line.
All
linked attributes tables are copied to the output vector map.
     cats=multi - If the lines that make up a polyline have different
category numbers then v.build.polylines will set the multiple catetory
numbers to a polyline. Also all linked attributes tables are copied to the
output vector map.
none of this options seems to work, as always all cats are copied to the
attribute table.
bug in v.build.polylines?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2505&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [ticket:2505 hellik]:
`cats=no` was indeed not working, fixed in r63321,2 (trunk, relbr70).
`v.build.polylines` is indeed copying all attribute tables as is from
input to output, but the categories are processed according to the cats
option. This means that the attribute table(s) can contain spurious
entries that do not match any output feature. Other (not all) modules also
copy attribute tables from input to output as is, without filtering.
Usually, this does not harm and is not even noticeable.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2505#comment:1&gt;
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:1 mmetz]:
Should this go also into GRASS 6?
Is this ticket solved?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2505#comment:2&gt;
Priority: major | Milestone: 7.0.0
      Cpu: Unspecified |
Changes (by hellik):
  * priority: critical => major
Comment:
Replying to [comment:2 neteler]:
confirmed cats=no is working now
above should go into the manual.
downgrading priority; closing ticket when manual is extended.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2505#comment:3&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:3 hellik]:
some notes added to manual: r63781 (trunk), r63782 (relbranch7)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2505#comment:4&gt;
Resolution: | Keywords: v.build.polylines
       CPU: Unspecified | Platform: All
Comment (by mlennert):
Can we close this ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505#comment:5&gt;
Comment (by neteler):
> > `cats=no` was indeed not working, fixed in r63321,r63322 (trunk,
relbr70).
Still unclear.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505#comment:6&gt;
Replying to [comment:6 neteler]:
relbr70).
> Still unclear.
What is actually unclear for me is what the problem was.
With a simple test line, when I comment out the line added in r63321 I get
the same results as when I leave it active, both in grass64_release and in
trunk. Both results being as expected. I have a vague memory that I could
reproduce the bug at the time, but can't remember the details.
Does someone have a more relevant test case ?
Then again, r63321 seems sufficiently non-invasive that it could probably
just be backported.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505#comment:7&gt;
  Priority: major | Milestone: 6.4.5
Component: Vector | Version: svn-releasebranch64
Changes (by neteler):
* version: svn-releasebranch70 => svn-releasebranch64
* milestone: 7.0.0 => 6.4.5
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505#comment:8&gt;
Comment (by wenzeslaus):
Replying to [comment:7 mlennert]:
That's why every ticket and/or commit should have a formalized test.
So, let me encourage everybody to provide tests as
[http://grass.osgeo.org/grass71/manuals/libpython/gunittest_testing.html
gunittest Python test],
#tests-as-general-scripts Bash script], or at least as steps to reproduce
in command line with easily available data, preferably NC SPM or
generated. Having the test it would be clear what was the problem, how to
reproduce it, and what the commit is trying to fix or implement (and if it
is successful). And it would be clear not only at the time of reporting or
writing but also half year later (which is the current age of the ticket).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505#comment:9&gt;
Comment (by hellik):
relbr70).
> > Still unclear.
as mentioned above:
''cats=no was indeed not working, fixed in r63321,2 (trunk, relbr70).''
some tests (testvector ''testlinetopolyline'' for nc sample dataset
attached later):
v.report map=testlinetopolyline@testvpolylines option=length
cat|length
1|3687.50148595
2|2416.07670918
3|3679.17100439
v.build.polylines --verbose input=testlinetopolyline@testvpolylines
output=catsmulti cats=multi
v.report map=catsmulti@testvpolylines option=length
cat|length
1|9782.74919952
2|9782.74919952
3|9782.74919952
output=catsfirst cats=first
v.report map=catsfirst@testvpolylines option=length
cat|length
1|9782.74919952
output=catsno
v.report map=catsno@testvpolylines option=length
cat|length
Lese Objekte...
cats=no is now working (not tested in grass6.x).
the second issue:
''some notes added to manual: r63781 (trunk), r63782 (relbranch7)''
tested with
GRASS Version: 7.0.0
GRASS SVN Revision: 64706
Erstellungsdatum: 2015-01-20
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505#comment:10&gt;
* Attachment "testlinetopolyline.txt" added.
test vector (ascii format) for nc sample dataset
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505&gt;
Replying to [comment:10 hellik]:
relbr70).
> > > Still unclear.
> as mentioned above:
I understand what the declared issue was and saw the fix, but what is
weird is that using current trunk, when I undo the fix by commenting out
the 'Vect_reset_cats(Cats);' call that was added, v.build.polyline still
works as expected with your test data. And everything works as expected
for me in grass64release as well, without the fix.
So I'm not sure that the "fix" actually solved the problem.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505#comment:11&gt;
Replying to [comment:11 mlennert]:
(trunk, relbr70).
> > > > Still unclear.
> > as mentioned above:
relbr70).''
> Moritz
a few months ago some issues with v.build.polylines were reported in the
MLs.
at that time I've tested a lot, ''cats=no'' didn't work in any case.
as my C knowledge is about zero, I can't judge if the fix mentioned in the
ticket or any other commit 'fixed' this; but it is fixed now which was
tested in the last days.
taken from the ML at that time:
to
the segments.
there may be hidden some more issues...
in quick summary in order to get solution to this ticket:
- cats=first, cats=multi, cats=no: tested here with g7 and trunk => works
now as expected
- no filtering database entries (see above) => manual in g7 and trunk was
expanded
- v.build.polylines seems to work as expected in the g6-series
as all seems to be fixed or working as normal, I suggest to close the
ticket. feel free to reopen the ticket.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505#comment:12&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.build.polylines
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505#comment:13&gt;
