[GRASS-dev] [GRASS GIS] #2510: v.db.addcolumn, bad parser syntax in script causes error, cascades to other modules
modules
Reporter: isaacullah | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Keywords: parser, syntax, error, script | Platform: Linux
      Cpu: x86-64 |
     In latest version of 7 from GRASS stable Ubuntu PPA archive,
v.db.addcolumn is broken because of a change to the parser code in the
script. The error is:
ERROR: Sorry, <map> is not a valid parameter
ERROR: Required parameter <output> not set:
         (Name for output vector map)
But this is because the only options are "output", and "map" and "layer"
don't show up. Looking at the script, I see that the relevant parser code
in the header is this:
#%module
#% description: Adds one or more columns to the attribute table connected
to a given vector map.
#% keywords: vector
#% keywords: attribute table
#% keywords: database
#%end
#%option G_OPT_V_MAP
#%end
#%option G_OPT_V_FIELD
#% label: Layer number where to add column(s)
#%end
#%option
#% key: columns
#% type: string
#% label: Name and type of the new column(s) ('name type [,name type,
#% description: Data types depend on database backend, but all support
VARCHAR(), INT, DOUBLE PRECISION and DATE
#% required: yes
#%end
It's obvious that it's the "G_OPT_V_MAP" and "G_OPT_V_FIELD" that are
causing the error. I've not ever used that syntax in my own scripts (I
wasn't aware that one *cold* do that, actually), but th error is fixed by
changing to the "normal" parser syntax:
#%module
#% keywords: vector
#%end
#%option
#% key: map
#% type: string
#% gisprompt: old,vector,vector
#% label: Name of map to add columns to the database
#% required: yes
#%end
#%option
#% key: layer
#% type: integer
#% answer: 1
#% required: yes
#%end
#%option
#% key: columns
#% type: string
#% required: yes
#%end
Not sure if the v.db.addcolumn code was always like that, and the error is
caused by some other change, or if this is due to a recent change to the
script itself, but it seems like an easy fix. This is a serious bug
because it breaks a lot of the other vector tools.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2510&gt;
modules
Keywords: parser, v.db.addcolumn | Platform: Linux
      Cpu: x86-64 |
Changes (by neteler):
  * keywords: parser, syntax, error, script => parser, v.db.addcolumn
Comment:
Replying to [ticket:2510 isaacullah]:
> Hi all,
Is it really the latest you are using there? We have made a major code
cleanup, perhaps
the package was created in the "transition days"?
I just tried, works fine with the really current version:
GRASS 7.0.0svn (nc_spm_08_grass7):~ > v.db.addcolumn random column="el102
double precision"
GRASS 7.0.0svn (nc_spm_08_grass7):~ > g.version -g
version=7.0.0svn
date=2014
revision=63285M
build_date=2014-12-03
build_platform=x86_64-unknown-linux-gnu
Ticket URL: <http://trac.osgeo.org/grass/ticket/2510#comment:1&gt;
modules
Resolution: | Keywords: parser, v.db.addcolumn
       CPU: x86-64 | Platform: Linux
Comment (by mlennert):
Can we close this ? I also get the map parameter as expected.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2510#comment:2&gt;
modules
      Type: defect | Status: closed
Resolution: fixed | Keywords: parser, v.db.addcolumn
* status: new => closed
* resolution: => fixed
Comment:
Closing, reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2510#comment:3&gt;
