#2519: KeyError: 'endcolor' in d.vect.thematic
Reporter: jamesp670 | Owner: grass-dev@…
Type: defect | Status: new
Component: Vector | Version: svn-releasebranch70
Keywords: | Platform: Linux
Cpu: x86-64 |
What I expect:
My d.vect.thematic command, reading
: GRASS 7.0.0svn (rlis-master-for-seven):/tmp > d.vect.thematic -f -s
--verbose map=tract2010censusdp1_clipped_02@PERMANENT column=popden10
themetype=graduated_colors themecalc=custom_breaks breakpoints="0 500 1000
1500 2000 5000 10000 15000 20000 25000" colorscheme=green-red monitor=none
-u
should work.
What I get:
: Traceback (most recent call last):
: File "/opt/yum-packages-installed-on-the-head-
node/tmp/local/grass-7.0.0svn/scripts/d.vect.thematic", line 1105, in
<module>
: main()
node/tmp/local/grass-7.0.0svn/scripts/d.vect.thematic", line 237, in main
: endcolor = options['endcolor']
Ticket URL: <http://trac.osgeo.org/grass/ticket/2519>
