[GRASS-dev] [GRASS GIS] #2522: d.vect.thematic, d.thematic.area in GRASS 7.0
Reporter: martinl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Keywords: d.vect.thematic, d.thematic.area | Platform: Unspecified
      Cpu: Unspecified |
Currently we have two modules for thematic rendering vector data:
  * d.vect.thematic
  * d.thematic.area
d.vect.thematic is a Python script which has been rewritten from Bash
based on code from GRASS 6. This module runs several times d.vect command
to render thematic data. This makes an integration of this module in wxGUI
as problematic.
d.thematic.area is a C module which use C library. This make this module
quicker to render data and more flexible. The code can be shared eg. with
v.colors to calculate breaks, etc. Unfortunately it's just written for
areal features and seems to be somehow not finished.
My suggestion is (before GRASS 7 release):
  * to move python script `d.vect.thematic` to addons
  * rename `d.thematic.area` to `d.thematic` or better `d.vect.thematic`
(in this case to rename `d.vect.thematic` in addons to `d.vect.thematic2`)
- any other name?
In the future to improve C module based on functionality of Python script.
Any comments, ideas?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2522&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [ticket:2522 martinl]:
I moved `d.vect.thematic` to addons as `d.vect.thematic2` in r63974:63975
- any other name?
done in r63976:63983. If no objection I will backported to relbr70.
script.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2522#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: d.vect.thematic, d.thematic.area
  Platform: Unspecified | Cpu: Unspecified
Changes (by martinl):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:1 martinl]:
done r64002. Closing this ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2522#comment:2&gt;
