#2524: wxGUI v.in.ogr wrapper fails to find any layers if file path contains non-
latin letters
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.4.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: encoding
CPU: Unspecified | Platform: MSWindows Vista
Comment (by hellik):
Replying to [comment:6 marisn]:
> Tested import tool (File -> Import vector -> Common formats) - when
choosing a Shapefile, no layers are listed and thus it is still impossible
to import anything.
> This issue affects also v.import and v.in.ogr as all of them seem to
share the same UI components.
> GRASS versija: 7.3.svn
> GRASS SVN revīzija: r70508
> Būvējuma datums: 2017-01-09
> Būvēšanas platforma: x86_64-w64-mingw32
> GDAL: 2.1.2
> PROJ.4: 4.9.3
> GEOS: 3.5.0
> SQLite: 3.14.1
> Python: 2.7.5
> wxPython: 2.8.12.1
> Platforma: Windows-8-6.2.9200 (OSGeo4W
confirmed, tested here:
System Info
GRASS version: 7.2.0
GRASS SVN revision: r70156
Build date: 2016-12-29
Build platform: x86_64-w64-mingw32
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
File "C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8
-msw-unicode\wx\lib\filebrowsebutton.py", line 140, in
OnChanged
self.changeCallback(evt)
File "C:\OSGEO4~1\apps\grass\grass-7.2.0\gui\wxpython\gui_
core\gselect.py", line 2055, in OnUpdate
self._reloadLayers()
core\gselect.py", line 2103, in _reloadLayers
input=dsn)
File "C:\OSGEO4~1\apps\grass\grass-7.2.0\gui\wxpython\core
\gcmd.py", line 705, in RunCommand
quiet, verbose, **kwargs))
File "C:\OSGEO4~1\apps\grass\grass-7.2.0\etc\python\grass\
script\core.py", line 311, in make_command
args.append(opt + b'=' + _make_val(val))
script\core.py", line 98, in _make_val
return encode(val)
script\utils.py", line 177, in encode
return string.encode(enc) if enc else string.encode()
File "C:\OSGEO4~1\apps\Python27\lib\encodings\cp1252.py",
line 12, in encode
return codecs.charmap_encode(input,errors,encoding_table)
UnicodeEncodeError
'charmap' codec can't encode character u'\u013c' in position
36: character maps to <undefined>
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r70750M
Build date: 2017-03-14
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
OnChanged
File "C:\OSGEO4~1\apps\grass\grass-7.3.svn\gui\wxpython\gu
i_core\gselect.py", line 2071, in OnUpdate
i_core\gselect.py", line 2119, in _reloadLayers
input=dsn)
File "C:\OSGEO4~1\apps\grass\grass-7.3.svn\gui\wxpython\co
re\gcmd.py", line 705, in RunCommand
File "C:\OSGEO4~1\apps\grass\grass-7.3.svn\etc\python\gras
s\script\core.py", line 312, in make_command
s\script\core.py", line 99, in _make_val
return encode(val)
s\script\utils.py", line 184, in encode
line 12, in encode
UnicodeEncodeError
Ticket URL: <https://trac.osgeo.org/grass/ticket/2524#comment:7>
