#2525: Unable to open sqlite database if path contains non-latin letters
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.6.2
Component: wxGUI | Version: svn-releasebranch70
Resolution: | Keywords: attribute
CPU: Unspecified | Platform: MSWindows Vista
Comment (by marisn):
Replying to [comment:13 sbl]:
> In 7.6, the state is actually worse, if the mapset contains non-ascii
characters...
Mapset names should not contain non-ascii chars. This issue was about
cases when mapset name is OK, but path leading to it contains non-ascii
chars.
Unfortunately I could not test the issue as GRASS failed to start on
Windows at all due to #3837
Ticket URL: <https://trac.osgeo.org/grass/ticket/2525#comment:14>
