[GRASS-dev] [GRASS GIS] #2528: r.shade not in menu
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
The new r.shade module is not in the menu. It should probably go under
raster/manage colors or raster/terrain analysis.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords:
  Platform: Unspecified | Cpu: Unspecified
Changes (by annakrat):
  * status: new => closed
  * resolution: => invalid
Comment:
The same as #2527.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:1&gt;
      Type: defect | Status: reopened
Resolution: | Keywords:
Changes (by cmbarton):
  * status: closed => reopened
  * resolution: invalid =>
Comment:
This IS missing from a fresh checkout of GRASS 7.0 beta 4. I am reopening.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:2&gt;
Resolution: | Keywords: toolboxes, menu, r.shade
Changes (by wenzeslaus):
  * keywords: => toolboxes, menu, r.shade
Comment:
Replying to [comment:2 cmbarton]:
reopening.
Same as #2527. It should be already in beta4. It is in the source code:
  * trunk: source:grass/trunk/gui/wxpython/xml/toolboxes.xml#L786
  * 70 release branch:
source:grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml#L786
  * 700beta4 tag:
source:grass/tags/release_20141222_grass_7_0_0beta4/gui/wxpython/xml/toolboxes.xml#L788
Please look to source code you are using, do `svn status`, `svn diff` and
`svnversion`. Run also `g.version -ge`. Clean your GRASS with:
make clean
make distclean
svn revert -R .
Then remove all what `svn status` is reporting as untracked (`? ...`).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:3&gt;
Comment(by neteler):
reopening.
I suspect a local problem because Vaclav changed it properly:
http://trac.osgeo.org/grass/changeset/63636#file5
Timestamp: 12/19/14 20:56:06
which was 3 days before tagging beta4:
http://trac.osgeo.org/grass/browser/grass/tags/release_20141222_grass_7_0_0beta4
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:4&gt;
Comment(by cmbarton):
To clarify:
1. The problem is not that the modules are missing but that they are not
available from the GRASS menu.
2. The beta 4 source I used was a fresh checkout, not an update.
Given the discussion, I suspect that the problem likes in the broken
./wxpython/XML compiling. I am checking now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:5&gt;
I can confirm that this is a function of the broken XML compiling. I tried
3 different workarounds. The 3rd one finally created the proper menus with
the missing modules (and maybe others I hope).
Since we are no longer building the menu tree manually (in theory a good
idea), it is very important that this compiles properly.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:6&gt;
Comment(by wenzeslaus):
Replying to [comment:6 cmbarton]:
tried 3 different workarounds. The 3rd one finally created the proper
menus with the missing modules (and maybe others I hope).
I don't know what are your workarounds. The only workaround I know about
is to run `make` in `gui/wxpython` directory inside running GRASS session.
This so far worked for everybody who needed that.
The fact that GUI started for you and that you had some menus shows that
you had some menu or toolbox XMLs somewhere. Perhaps you experimented with
custom menus and you had something in home directory? Or you were running
different GRASS? Or compiling to directory with existing build? Or you
might be doing install step which I personally haven't tested much but
there were no problems so far?
As I said earlier, I don't know how to fix the compilation. Martin tried
and it helped for some cases but not for all. The best solution I can do
is to make toolboxes independent on wxGUI which is discussed in #2142.
However, it is important to know that this just hides the compilation
issue by not requiring complete runtime environment during compilation,
specifically no wxPython. I had no time to work on it so far but all I
know is noted in the ticket, so feel free to re-assign.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:7&gt;
Is there some way to force an update to the menu from the command line
after compilation? A couple of the workarounds involved running a python
make from within GRASS.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:8&gt;
Workarounds:
1. a) Make GRASS,
b) make binary package (bindist),
c) start binary (gui crashes)
d) cd to wxpython folder inside binary package from the GRASS terminal
(e.g.,
/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython),
and run make)
Failed to update xml for me
2. a) Make GRASS,
b) make binary package (make bindist),
c) start binary (gui crashes),
(e.g.,
e) run the following
python core/toolboxes.py > xml/menudata.xml
python core/toolboxes.py "module_tree" > xml/module_tree_menudata.xml
f) Next, copy the newly created menudata.xml and module_tree_menudata.xml
files from the binary package back to the compiled but not packaged
distribution (in ../dist.x86_64-apple-darwin13.0.0),
g) rerun bindist to make a new package
This works
3. reuse the menudata.xml and module_tree_menudata.xml files in a new
GRASS compilation before doing a binary distribution with the (apparently
erroneous) assumption that these menu xml files dynamically updated when
GRASS was run.
Failed to update xml files
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:9&gt;
Replying to [comment:8 cmbarton]:
after compilation?
  * compile with `make`
  * run GRASS from `dist...` directory, i.e. using `bin.../grass..`
  * `cd` into `gui/wxpython`
  * `make clean`
  * `make`
This should work. If you want to recompile the toolboxes and not the whole
GRASS, use:
  * (in GRASS session)
  * `rm dist.../gui/wxpython/xml/*.xml`
  * `make clean`
  * `make`
If you want to script it, you probably have to start GRASS from command
line in the demo location and set the environmental variable
`GRASS_BATCH_JOB` to a script where you have the steps which must be
executed inside GRASS.
How it works with binary distribution or `make install`, especially on Mac
OS X, I have no idea but you can easily encounter some problems with
access rights or not execute the whole procedure, e.g. running just `make`
and not `make install`, I guess.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:10&gt;
Replying to [comment:9 cmbarton]:
> Workarounds:
> 1. a) Make GRASS,
IMHO you are missing 'make install' here which is needed before running
'make bindist'.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:11&gt;
make bindist runs instead of make install.
Make install is for Linux (though it can be used on the Mac too). Make
bindist makes a *.pkg file that can be generically installed on other
computers. It includes a package of additional files, including the
required version of wxPython, so that it will run on most other machines
without additional dependencies.
Make install won't fix the xml file problem as far as I can tell. This is
a failure during make. No one seems to be quite sure what is going on, but
it seems like Python code is called during make that ignores the
environment settings for the shell that make is running in. This causes
the Python code to fail and the xml files to not have their contents
updated.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:12&gt;
Replying to [comment:10 wenzeslaus]:
after compilation?
> * `make clean`
> * `make`
whole GRASS, use:
> * `make clean`
> * `make`
I'll try these. They might at least reduce the number of steps in a
workaround. Do you think that the 2nd one will work if I'm running any
GRASS 7 session? Or must it be the one just compiled?
Mac OS X, I have no idea
** This in general is part of the problem, not for you specifically but
for most GRASS devs **
but you can easily encounter some problems with access rights or not
execute the whole procedure, e.g. running just `make` and not `make
install`, I guess.
This is not a problem in my case at least. Thanks for the suggestions.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:13&gt;
Replying to [comment:13 cmbarton]:
line after compilation?
> > * `make clean`
> > * `make`
whole GRASS, use:
> > * `make clean`
> > * `make`
command line in the demo location and set the environmental variable
It could work but I wouldn't do that. Mixing two different GRASS versions
(in sense of directories/installations/compilations) will probably end up
in some confusion. The safe way is to use GRASS in `dist...` and `bin...`
directories of the code you are working with; this is the code which is
used during compilation if GRASS session is needed (and that's the
environment you are trying to fake it).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:14&gt;
Replying to [comment:14 wenzeslaus]:
> > > * `make clean`
> > > * `make`
whole GRASS, use:
> > > * `make clean`
> > > * `make`
versions (in sense of directories/installations/compilations) will
probably end up in some confusion. The safe way is to use GRASS in
`dist...` and `bin...` directories of the code you are working with; this
is the code which is used during compilation if GRASS session is needed
(and that's the environment you are trying to fake it).
I'd be using the same version, just a different revision. But to launch
the GRASS in the dist folder, what is the launching script called? I don't
see anything that is obvious.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:15&gt;
Replying to [comment:15 cmbarton]:
command line after compilation?
> > > > * `make clean`
> > > > * `make`
the whole GRASS, use:
> > > > * `make clean`
> > > > * `make`
Yes, using different revisions, this is what I meant. That's not a good
idea. It might turn against you one day.
> But to launch the GRASS in the dist folder, what is the launching script
called? I don't see anything that is obvious.
For the reasons I don't know, the script/binary to run GRASS from
`dist...` is in `bin...`:
$ ls bin.x86_64-unknown-linux-gnu/
grass71
$ ls dist.x86_64-unknown-linux-gnu/
AUTHORS driver locale
bin etc REQUIREMENTS.html
CHANGES fonts scripts
contributors.csv GPL.TXT share
contributors_extra.csv grass71.tmp tools
COPYING gui translation_status.json
demolocation include translators.csv
docs lib
$ head bin.x86_64-unknown-linux-gnu/grass71
#!/usr/bin/env python
# MODULE: GRASS initialization script
# AUTHOR(S): Original author unknown - probably CERL
# Andreas Lange <andreas.lange rhein-main.de>
# Huidae Cho <grass4u gmail.com>
# Justin Hickey <jhickey hpcc.nectec.or.th>
# Markus Neteler <neteler osgeo.org>
# Hamish Bowman <hamish_b yahoo.com>
$ ./bin.x86_64-unknown-linux-gnu/grass71 -text
Cleaning up temporary files...
Starting GRASS GIS...
> echo $GISBASE
.../dist.x86_64-unknown-linux-gnu
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:16&gt;
Replying to [comment:16 wenzeslaus]:
`bin.../grass..`
> > > > > * `make clean`
> > > > > * `make`
> > > > > * `make clean`
> > > > > * `make`
a workaround. Do you think that the 2nd one will work if I'm running any
script called? I don't see anything that is obvious.
> grass71
> docs lib
> > echo $GISBASE
This is for Linux.
AFAICT, it's not there for the Mac.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:17&gt;
Here is an update.
AFAICT, you can't run GRASS from the ../dist... folder on the Mac. It
won't start because it needs environmental settings provided by packaging
as an *.app.
I can run another version of GRASS, cd into the source ../wxpython
directory.
make clean
make
will create the xml files
running the following, without make clean will also generate them.
But then I have to copy the xml files into the ../dist... folder before
making a binary package.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:18&gt;
Resolution: invalid | Keywords: toolboxes, menu, r.shade
  * status: reopened => closed
Comment:
This was a local problem. Please, open a new ticket if you have other
issues.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:19&gt;
