GDAL
January 5, 2015, 9:47am
1
#2529: v.dissolve only dissolve attribute table but not topology
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Vector | Version: unspecified
Keywords: dissolve | Platform: MSWindows Vista
Cpu: x86-32 |
testet with
System Info
GRASS Version: 7.1.svn
GRASS SVN Revision: 63945
Erstellungsdatum: 2015-01-04
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
before dissolve
v.info map=testline_transect_area@user1
| Mapset: user1
| Datenbank: J:\gisdata
| Titel:
| Maßstab: 1:1
| Name des Erzeugers:normal
| Organisation:
| Quelldatum: Mon Jan 05 10:23:23 2015
| Timestamp (first layer): none
| Kartenformat: native
| Kartenart:: Vektor (level: 2)
| Anzahl der Punkte: 0 Anzahl der Zentroide: 82
| Anzahl der Linien: 0 Anzahl der Grenzen: 82
| Anzahl der Flächen: 82 Anzahl der Inseln: 82
| Map is 3D: No
| Anzahl der dblinks: 1
| Projektion: Lambert Conformal Conic
| N: 226486.974314 S: 215466.854851
| E: 641914.012535 W: 631036.302095
| Digitalisierungs-Schwellwert:: 0
| Kommentar:
after dissolve
v.info map=nexttrydis@user1
| Mapset: user1
| Titel:
| Maßstab: 1:1
| Organisation:
| Map is 3D: No
| Kommentar:
Ticket URL: <http://trac.osgeo.org/grass/ticket/2529> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
January 5, 2015, 10:25am
2
Cpu: x86-32 |
Comment(by neteler):
Can you upload the map (v.pack) or generate a reproducible example?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2529#comment:1> ;
GDAL
January 5, 2015, 12:43pm
3
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:1 neteler]:
vector attached and produced by:
v.extract input=streams@PERMANENT cats=83348 output=streams_oneline
addon v.transects:
v.transects --verbose input=streams_oneline@user1
output=streams_oneline_quads transect_spacing=100 dleft=50 dright=50
type=area
v.db.addtable map=streams_oneline_quads@user1
v.db.addcolumn map=streams_oneline_quads@user1 columns="dis integer"
v.db.update --verbose map=streams_oneline_quads@user1 layer=1 column=dis
value=1
Ticket URL: <http://trac.osgeo.org/grass/ticket/2529#comment:2> ;
GDAL
January 5, 2015, 12:50pm
4
Cpu: x86-32 |
Comment(by hellik):
also tested with nc sample data, there it seems to work:
g.copy vector=soils_wake@PERMANENT,mysoils_wake
v.db.addcolumn map=mysoils_wake@user1 columns="dis integer"
v.db.update map=mysoils_wake@user1 layer=1 column=dis value=1
v.dissolve input=mysoils_wake@user1 column=dis output=mysoils_wake_dis
v.info map=mysoils_wake@user1
| Mapset: user1
| Titel: South-West Wake County soils (polygon map)
| Maßstab: 1:1
| Name des Erzeugers:hmitaso
| Organisation:
| Quelldatum: Wed Dec 19 11:10:11 2007
| Anzahl der Punkte: 0 Anzahl der Zentroide: 3378
| Anzahl der Linien: 0 Anzahl der Grenzen: 9912
| Anzahl der Flächen: 3412 Anzahl der Inseln: 91
| Map is 3D: No
| N: 255570.75819148 S: 209185.32512061
| E: 658480.56896114 W: 625795.27559055
| Kommentar:
v.info map=mysoils_wake_dis@user1
| Mapset: user1
| Maßstab: 1:1
| Organisation:
| Anzahl der Punkte: 0 Anzahl der Zentroide: 1
| Anzahl der Linien: 0 Anzahl der Grenzen: 345
| Anzahl der Flächen: 35 Anzahl der Inseln: 33
| Map is 3D: No
| Kommentar:
Ticket URL: <http://trac.osgeo.org/grass/ticket/2529#comment:3> ;
GDAL
January 5, 2015, 12:52pm
5
Cpu: x86-32 |
Comment(by hellik):
tried after cleaning the example:
v.clean input=streams_oneline_quads@user1
output=streams_oneline_quads_clean type=point,line,area
tool=snap,break,rmdupl thres=0.01,0.01,0.01
v.dissolve --verbose input=streams_oneline_quads_clean@user1 column=dis
output=streams_oneline_quads_clean_dis
it doesn't help
Ticket URL: <http://trac.osgeo.org/grass/ticket/2529#comment:4> ;
GDAL
January 9, 2015, 9:12am
6
Cpu: x86-32 |
Comment(by mmetz):
Replying to [comment:4 hellik]:
> it doesn't help
You need to specify the feature type to be cleaned:
v.clean type=boundary
I do not understand why this is needed, but this helps.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2529#comment:5> ;
GDAL
January 9, 2015, 7:46pm
7
Type: defect | Status: closed
Resolution: fixed | Keywords: dissolve
Platform: MSWindows Vista | Cpu: x86-32
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:5 mmetz]:
> > it doesn't help
confirmed, after ''v.clean type=boundary'' v.dissolve works. closing
ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2529#comment:6> ;
