#2530: No Feedback from Layermanager when starting Gis.m
Reporter: timhirth90 | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: unspecified
Keywords: | Platform: MSWindows 7
Cpu: Unspecified |
Hello all,
Every time when im starting to use the Gismanager (with gis.m), i have got
a problem. If i open the manager with the command gis.m, the manager will
open, but if i klick back at Grass Layermanager or the Map Display, this
two parts wont work anymore. It says to me every time no feedback (no
support).
Im using Grass Gis 6.4.4 but i also had the problem when i tryed to use
Grass Gis 6.4.2. I have also tryed to install it at another computer. But
same Problems there.
The only way to get a feedback again from Layermanager is to close the
opened applications (wich i started with the command gis.m). When i close
them, i will get feedback from Layermanager and everything works fine.
I cant understand why the problem only begins, when i klick back at the
Layermanager or the Mapdisplay while the gis.m applications are opened.
The Problem cant be a problem by the Hardware. As i told, its a Problem at
different Computers with more then enough power.
Thanks for helping
Ticket URL: <http://trac.osgeo.org/grass/ticket/2530>
