[GRASS-dev] [GRASS GIS] #2539: v.in.ogr: error importing shapefiles: ValueError : too many values to unpack
unpack
Reporter: richardc | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Keywords: v.in.ogr vector import | Platform: Linux
      Cpu: x86-32 |
Probably related to https://trac.osgeo.org/grass/ticket/2537
I'm getting the following error on attempting to import a shape file,
without success, with v.in.ogr.
Layer Manager > File > Import vector data > Common import formats
[v.in.ogr] Browse to select file
From the command console:
   File "/usr/lib/python2.7/dist-
packages/wx-2.8-gtk2-unicode/wx/lib/filebrowsebutton.py",
line 140, in OnChanged
self.changeCallback(evt)
   File "/home/rcooper/grass70/grass-7.0.0svn/gui/wxpython/gu
i_core/gselect.py", line 1920, in OnUpdate
self._reloadLayers()
i_core/gselect.py", line 1945, in _reloadLayers
layerName, featureType, projection = map(lambda x:
x.strip(), line.split(','))
ValueError
And after clicking Import, I receive the following popup message:
No layers selected. Operation canceled
The above relates to 7.0.0svn:
System Info
GRASS version: 7.0.0svn
GRASS SVN Revision: 63929
Build Date: 2015-01-02
Build Platform: i686-pc-linux-gnu
GDAL/OGR: 1.11.1
PROJ.4: 4.9.0
GEOS: 3.4.2
SQLite: 3.7.9
Python: 2.7.3
wxPython: 2.8.12.1
Platform: Linux-3.2.0-31-generic-pae-i686-with-LinuxMint-13-maya
I've tried with a couple of shapefiles.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2539&gt;
unpack
Priority: blocker | Milestone: 7.0.0
Component: wxGUI | Version: svn-releasebranch70
Keywords: wxgui vector import wizard | Platform: Linux
      Cpu: x86-32 |
Changes (by mlennert):
  * keywords: v.in.ogr vector import => wxgui vector import wizard
  * priority: critical => blocker
  * component: Vector => wxGUI
Comment:
I can confirm this error on a freshly checkouted and compiled
grass70release tree.
Bumping this up to blocker as this is fundamental functionality of the
GUI.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2539#comment:1&gt;
unpack
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:1 mlennert]:
GUI.
tested and ''not'' confirmed by
System Info
GRASS Version: 7.1.svn
GRASS SVN Revision: 64069
Erstellungsdatum: 2015-01-12
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2539#comment:2&gt;
unpack
      Cpu: x86-32 |
Comment(by martinl):
I cannot reproduce this bug. Please can you check it again with the fresh
installation?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2539#comment:3&gt;
unpack
      Cpu: x86-32 |
Comment(by mlennert):
Replying to [comment:3 martinl]:
fresh installation?
I have trouble finding a clear logic in all this as sometimes it seems to
work and sometimes not. But I think I found a candidate of what might
explain it
[http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.external/list.c#L326
1], but only with gdal < 1.11 :
312 #if GDAL_VERSION_NUM >= 1110000
313 for (igeom = 0; igeom <
OGR_FD_GetGeomFieldCount(Ogr_featuredefn); igeom++) {
314 Ogr_geomdefn =
OGR_FD_GetGeomFieldDefn(Ogr_featuredefn, igeom);
315 if (!Ogr_geomdefn) {
316 G_warning(_("Invalid geometry column %d"),
igeom);
317 continue;
318 }
319
320 Ogr_geom_type =
OGR_GFld_GetType(Ogr_geomdefn);
321 fprintf(fd, "%s,%s,%d,%s\n", layer_name,
322
feature_type(OGRGeometryTypeToName(Ogr_geom_type)),
323 proj_same,
OGR_GFld_GetNameRef(Ogr_geomdefn));
324 }
325 #else
326 fprintf(fd, "%s,%s,%d,\n", layer_name,
327
328 proj_same);
329 #endif
Line 326 reads:
should the last comma really be there ? Erasing it away seems to solve the
problem for me.
However, this would not explain the problem for RichardC as he seems to be
working with gdal 1.11...
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2539#comment:4&gt;
unpack
      Cpu: x86-32 |
Replying to [comment:4 mlennert]:
fresh installation?
to work and sometimes not.
I updated `v.external` to report also geometry columns, see (1). The bug
was related to PostgreSQL format for which `v.external` is not using GDAL
library by default, but it's own implementation. Now it should be fixed.
(1) http://trac.osgeo.org/gdal/wiki/rfc41_multiple_geometry_fields
Ticket URL: <http://trac.osgeo.org/grass/ticket/2539#comment:5&gt;
unpack
      Cpu: x86-32 |
the problem for me.
sorry, what kind of problems?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2539#comment:6&gt;
unpack
      Cpu: x86-32 |
Replying to [comment:6 martinl]:
the problem for me.
The "ValueError: too many values to unpack" error when trying to use the
vector import wizard to import a shapefile. This is a different bug (but
probably of similar origin) than #2537.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2539#comment:7&gt;
unpack
      Cpu: x86-32 |
Replying to [comment:7 mlennert]:
As I already wrote, I cannot reproduce this bug. Are you sure that you
have a fresh installation?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2539#comment:8&gt;
unpack
      Cpu: x86-32 |
be working with gdal 1.11...
I have tested GRASS with GDAL 1.11, no problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2539#comment:9&gt;
unpack
      Cpu: x86-32 |
I'm really losing the little that is left of my hair over this... :wink:
I did a completely fresh checkout of relbr70 this morning and could
confirm the issue. Now I did the same and the issue seems to have gone
away. IIUC, the issue was fixed with r64041, changing
layerName, featureType, projection = map(lambda x: x.strip(),
line.split(','))
to
layerName, featureType, projection, geometryColumn = map(lambda x:
in gui/wxpython/gui_core/gselect.py, thus solving the issue of only three
variables, but four values.
I don't understand why I still saw this error this morning, though.
I'll check out, recompile and test tomorrow on other machines running with
gdal 1.10. I'll keep it open until then.
P.S. Could it be that certain gui files are not updated with 'make
distclean; svn up; configure; make' ? I shouldn't have to do fresh
checkouts everytime...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2539#comment:10&gt;
unpack
      Type: defect | Status: closed
Resolution: fixed | Keywords: wxgui vector import wizard
  Platform: Linux | Cpu: x86-32
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:10 mlennert]:
line.split(','))
> to
three variables, but four values.
with gdal 1.10. I'll keep it open until then.
Just did that with relbr7 and everything seems to work, now. Thanks for
the fixes.
Closing the ticket.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2539#comment:11&gt;
