GDAL
January 14, 2015, 11:10am
1
#2548: map display 3d view: error to display vector point
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: MSWindows 7
Cpu: x86-64 |
tested with
System Info
GRASS Version: 7.1.svn
GRASS SVN Revision: 64069
Erstellungsdatum: 2015-01-12
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
error message:
File "C:\OSGeo4W\apps\grass\grass-7.1.svn\gui\wxpython\nvi
z\tools.py", line 2787, in OnSetRaster
self.UpdateSurfacePage(layer, data, updateName = False)
z\tools.py", line 4736, in UpdateSurfacePage
self.OnSurfaceAxis(None)
z\tools.py", line 3286, in OnSurfaceAxis
id = data['surface']['object']['id']
KeyError
'object'
Lade Rasterkarte <N47E012@myricaria>...
Übersetze Farben der Rasterkarte <N47E012@myricaria>...
Vektorkarte <grosspoint2@myricaria> geladen (1 Punkte).
steps done:
- load DEM to map display
- load point vector (1 point) to map display
- switch to 3d view
raster is displayed in 3d view, but not the vector
Ticket URL: <http://trac.osgeo.org/grass/ticket/2548> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
January 14, 2015, 2:40pm
2
Cpu: x86-64 |
Comment(by annakrat):
I can't reproduce this on Ubuntu. Does this happen with fresh gui
instance?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2548#comment:1> ;
GDAL
January 14, 2015, 3:03pm
3
Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:1 annakrat]:
instance?
now tested with the nc sample data set
Starte 3D-Ansichtsmodus...
Lade Rasterkarte <elevation@PERMANENT>...
Übersetze Farben der Rasterkarte <elevation@PERMANENT>...
Vektorkarte <firestations@PERMANENT> geladen (15 Punkte).
Wechsle zu 2D-Ansicht zurück...
Rasterkarte <elevation@PERMANENT> erfolgreich entfernt
Vektorkarte <firestations@PERMANENT> (points) erfolgreich entfernt
KeyError
'object'
Vektorkarte <overpasses@PERMANENT> geladen (117 Punkte).
to reproduce in nc sample data set:
- load elevation
- load firestation
- switch to 3d view
- switch back to 2d view
- remove firestation from map display
- add overpasses vector to map display
- switch to 3d view
Ticket URL: <http://trac.osgeo.org/grass/ticket/2548#comment:2> ;
GDAL
January 14, 2015, 3:20pm
4
Cpu: x86-64 |
So it seems Windows only problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2548#comment:3> ;
GDAL
February 27, 2015, 6:18pm
5
Cpu: x86-64 |
Comment(by marisn):
Replying to [comment:3 annakrat]:
Observed the same problem on XP and Vista with 7.0.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/2548#comment:4> ;
