#2548: map display 3d view: error to display vector point
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.6
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:3 annakrat]:
> So it seems Windows only problem.
tested by
System Info
GRASS version: 7.2.svn
GRASS SVN revision: r69794
Build date: 2016-11-13
Build platform: x86_64-w64-mingw32
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200
with the NC example mentioned above.
Starting 3D view mode...
File "C:\Program Files\GRASS GIS
7.2.svn\gui\wxpython\nviz\tools.py", line 3247, in
OnSetRaster
self.UpdateSurfacePage(layer, data, updateName=False)
7.2.svn\gui\wxpython\nviz\tools.py", line 5370, in
UpdateSurfacePage
self.OnSurfaceAxis(None)
7.2.svn\gui\wxpython\nviz\tools.py", line 3784, in
OnSurfaceAxis
id = data['surface']['object']['id']
KeyError
'object'
Loading raster map <elevation@PERMANENT>...
Translating colors from raster map <elevation@PERMANENT>...
Vector map <overpasses@PERMANENT> loaded (117 points)
it's in the winGRASS7.0.x and winGRASS7.2.line.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2548#comment:7>
