[GRASS-dev] [GRASS GIS] #2551: g.gui.tplot error message
  Reporter: hellik | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: normal | Milestone: 7.0.7
Component: Temporal | Version: svn-trunk
Resolution: | Keywords:
       CPU: x86-64 | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:5 veroandreo]:
> is this still an issue?
tested with
System Info
GRASS version: 7.4.0
GRASS SVN revision: r72154
Build date: 2018-01-27
Build platform: x86_64-w64-mingw32
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
opening and closing the first time
Exception
IOError
(6, 'Das Handle ist ung\xfcltig')
  in
<bound method TplotFrame.__del__ of <tplot.frame.TplotFrame;
proxy of <Swig Object of type 'wxFrame *' at 0x14efcd80> >>
  ignored
opening the second time
WARNING:root:Needed to restart the libgis server, caller:
main thread
closing the second time
Exception
IOError
  in
  ignored
and also tested with
System Info
GRASS version: 7.5.svn
GRASS SVN revision: r72376
Build date: 2018-03-17
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Exception
IOError
  in
proxy of <Swig Object of type 'wxFrame *' at 0x150a7eb0> >>
  ignored
main thread
Exception
IOError
  in
proxy of <Swig Object of type 'wxFrame *' at 0x154a1a10> >>
  ignored
still some issues, but it seems different from the original report
Ticket URL: <https://trac.osgeo.org/grass/ticket/2551#comment:6&gt;
