#2552: GRASS 7.0 RC1 wxGUI: fails to launch in Spanish locale (UnicodeEncodeError)
Reporter: santipardo | Owner: grass-dev@…
Type: defect | Status: new
Component: wxGUI | Version: svn-releasebranch70
Keywords: | Platform: Linux
Cpu: x86-64 |
With Spanish locale (es_ES.UTF-8), GRASS 7.0 RC1 doesn't launch. I have
launched it perfectly in the same installation with locale en_US-UTF-8.
The problem is happening since beta 4.0.
CONF:
Linux Mint 17.1
$ locale | grep LANG
LANG=es_ES.UTF-8
TERMINAL OUTPUT:
Launching <wxpython> GUI in the background, please wait...
File "/usr/bin/grass70", line 1461, in <module>
bash_startup()
File "/usr/bin/grass70", line 1122, in bash_startup
_("3D raster MASK present")))
UnicodeEncodeError: 'ascii' codec can't encode character u'\xc1' in
position 180: ordinal not in range(128)
ERROR: Variable 'LOCATION_NAME' not set
File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 37, in <module>
from lmgr.frame import GMFrame
File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 50, in <module>
from lmgr.layertree import LayerTree, LMIcons
File "/usr/lib/grass70/gui/wxpython/lmgr/layertree.py", line 37, in
<module>
from mapdisp.frame import MapFrame
File "/usr/lib/grass70/gui/wxpython/mapdisp/frame.py", line 65, in
<module>
class MapFrame(SingleMapFrame):
File "/usr/lib/grass70/gui/wxpython/mapdisp/frame.py", line 71, in
MapFrame
page = None, Map = Map(), auimgr = None, name = 'MapWindow',
**kwargs):
File "/usr/lib/grass70/gui/wxpython/core/render.py", line 408, in
__init__
self.mapfile = grass.tempfile(create = False) + '.ppm'
File "/usr/lib/grass70/etc/python/grass/script/core.py", line 704, in
tempfile
return read_command("g.tempfile", flags=flags,
pid=os.getpid()).strip()
File "/usr/lib/grass70/etc/python/grass/script/core.py", line 427, in
read_command
return handle_errors(returncode, stdout, args, kwargs)
File "/usr/lib/grass70/etc/python/grass/script/core.py", line 310, in
handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.tempfile', '-d',
'pid=2237'] ended with error
Process ended with non-zero return code 1. See errors in the (error)
output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2552>
