[GRASS-dev] [GRASS GIS] #2553: v.kriging: ogr_api.h: No such file or directory
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: svn-trunk
Keywords: v.kriging ogr_api.h | Platform: Linux
      Cpu: Unspecified |
Trying to install v.kriging, both via the g.extension wxGUI, or from the
addons source tree, I get the following error:
$ LANG=C make MODULE_TOPDIR=../../../../grass_trunk/dist.x86_64-unknown-
linux-gnu/
c++ -g -O2 -I/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64
-unknown-linux-gnu/include
-I/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-unknown-linux-
gnu/include -fopenmp -DPACKAGE=\""grassmods"\"
-I/usr/include/postgresql -I/usr/include/pcl-1.7 -I/usr/include/eigen3
gnu/include -I/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64
-unknown-linux-gnu/include -DRELDIR=\"/data/home/mlennert/SRC/GRASS/grass-
addons/grass7/vector/v.kriging\" -o OBJ.x86_64-unknown-linux-gnu/utils.o
-c utils.cpp
In file included from
gnu/include/grass/vect/digit.h:3:0,
                  from
gnu/include/grass/vector.h:4,
                  from local_proto.h:16,
                  from utils.cpp:1:
gnu/include/grass/vect/dig_structs.h:27:21: fatal error: ogr_api.h: No
  #include <ogr_api.h>
compilation terminated.
../../../../grass_trunk/dist.x86_64-unknown-linux-
gnu//include/Make/Compile.make:35: recipe for target 'OBJ.x86_64-unknown-
linux-gnu/utils.o' failed
make: *** [OBJ.x86_64-unknown-linux-gnu/utils.o] Error 1
When I had a similar error a long time ago with i.pr, the solution was to
add 'EXTRA_CFLAGS = $(VECT_CFLAGS)' to the Makefile
[http://lists.osgeo.org/pipermail/grass-dev/2007-November/034353.html 1].
However, v.kriging's Makefile already contains that line.
$ gdal-config --cflags
-I/usr/include/gdal
System info:
Version de GRASS: 7.1.svn
Version SVN: 64098
Build Date: 2015-01-12
Build Platform: x86_64-unknown-linux-gnu
GDAL/OGR: 1.10.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.8.7.1
Python: 2.7.8
wxPython: 3.0.1.1
Plateforme: Linux-3.16.0-4-amd64-x86_64-with-debian-jessie-sid
Ticket URL: <https://trac.osgeo.org/grass/ticket/2553&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.kriging, ogr_api.h
  Platform: Linux | Cpu: Unspecified
Changes (by neteler):
  * keywords: v.kriging ogr_api.h => v.kriging, ogr_api.h
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in r64242 - it requires also
EXTRA_INC = ... $(PROJINC)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2553#comment:1&gt;
