#2559: g.gui.metadata not functioning
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Different error messages depending on what type of data is involved
(raster or vector):
'''rasters:''' Editing or creating metadata files seems impossible, see
first error message.
File "/home/paulo/.grass7/addons/scripts/g.gui.metadata",
line 1031, in onEdit
ok = self.GetParent().onEditMapMetadata()
line 257, in onEditMapMetadata
self.mdCreator.createGrassBasicISO()
File "/home/paulo/.grass7/addons/etc/mdlib/mdgrass.py",
line 186, in createGrassBasicISO
self.md.identification.title =
mdutil.replaceXMLReservedChar(self.md_grass['title'])
KeyError: 'title'
'''Vectors:''' Problem differs depending on whether the layer exist:
1) Using the edit button for a layer for which there is no metadata file
yet results in an error message (below). Note that notwithstanding the
message, the /basicTemplate.xml is present in the templates folder.
2) If there is a metadata file, but I select another template, I get the
error message as below
3) If there is a metadata file, and I select the template in which that
metadata was written, the window to edit opens and I can edit. I can
however not save the edits.
line 259, in onEditMapMetadata
self.xmlPath =
self.mdCreator.saveXML(self.mdDestination,
self.nameTMPteplate, self)
line 346, in saveXML
template = env.get_template(self.template)
File "/usr/lib/python2.7/dist-
packages/jinja2/environment.py", line 791, in get_template
return self._load_template(name,
self.make_globals(globals))
packages/jinja2/environment.py", line 765, in _load_template
template = self.loader.load(self, name, globals)
File "/usr/lib/python2.7/dist-packages/jinja2/loaders.py",
line 113, in load
source, filename, uptodate =
self.get_source(environment, name)
line 178, in get_source
raise TemplateNotFound(template)
jinja2.exceptions.TemplateNotFound:
/home/paulo/.grass7/addons/etc/templates/basicTemplate.xml
Ticket URL: <http://trac.osgeo.org/grass/ticket/2559>
