#2563: r.grow.distance: define max distance
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: r.grow.distance maximum distance | Platform: Unspecified
Cpu: Unspecified |
It would be nice if r.grow.distance allowed to define a maximum distance.
The module could then stop calculating once this maximum distance is
attained (e.g. similar to r.cost's max_cost option). This should probably
accelerate the module if only short distances are needed from the starting
points.
Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:2563 mlennert]:
distance. The module could then stop calculating once this maximum
distance is attained (e.g. similar to r.cost's max_cost option). This
should probably accelerate the module if only short distances are needed
from the starting points.
It wouldn't have the slightest effect upon performance. r.grow.distance
doesn't operate in order of increasing distance. It operates row-by-row in
two passes, from top-to-bottom then bottom-to-top, recording the distance
to the closest point seen so far.
Replying to [comment:1 glynn]:
Ok, so the only way to limit the distance is to determine the smallest
region that would include the max distance.
