#2568: Upper-lower case issues with sqlite driver and affect on v.db.reconnect.all
Reporter: ewcgrass | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Database | Version: svn-releasebranch70
Keywords: | Platform: Linux
Cpu: x86-64 |
I am rebuilding an number of existing mapsets from GRASS 6.4.4 (svn 02 Nov
2013) to GRASS 7.0.0 (svn 17 Jan 2015), per the directions given in the
wiki. The 6.4.4 mapset database files are in .dbf format, with conversions
being done to sqlite format. v.build.all works fine, as does db.connect
-d, but v.db.reconnect.all terminates early when it encounters a .dbf
table that has the name "CAT" (upper case) in the key column, as opposed
to "cat" (lower case).
What happens is the sqlite table is created with all the attributes being
properly copied over, but the sqlite table refuses to connect to the
vector file. Once the .dbf table has been converted to sqlite format, then
I can change the case of the key column using sqliteman, after which the
table and vector file will then connect properly using either v.db.connect
or v.db.reconnect.all. However, v.db.reconnect.all will terminate early
again upon encountering the next .dbf table in which the key column is
"CAT" in upper case.
I can show the .dbf table attibutes by right-clicking on the vector map
being converted (after having used v.build.all, of course) on the layer
manager gui, and can access the "manage table" tab in the gui that
appears. However, it shows "cat" in lower case when it is in fact in upper
case "CAT", and will not allow the name to be changed from "CAT" to "cat"
because the name cat already exists, nor will it allow CAT to be changed
temporarily to something like "cat1" as a temporary place holder so it can
be changed again to "cat", since "cat" or "CAT" is required in the key
column.
The .dbf tables that cause this problem are tables that have been modified
and saved using OpenOffice or LibreOffice calc, which defaults to saving
all column names to upper case.
I could get around this issue by repeatedly using v.db.reconnect.all and
sqliteman until all tables have been properly copied over and connected,
but that defeats the whole purpose of having v.db.reconnect.all in the
first place, and also highlight the problem that exists with the sqlite
driver regarding column name capitalization, which is something that is
likely to affect many other GRASS users.
My suggest(s) for correcting this would be to either have a means of
ignoring errors in v.db.reconnect.all (but this could cause other yet
undefined problems), or to have the sqlite driver (or whatever other GRASS
module is used by v.db.reconnect.all that is causing early termination) to
accept "CAT" as well as "cat".
This issue does not appear to be a random one, since I have been able to
encounter it and correct it (by recursively using sqliteman with
v.db.reconnect.all and/or v.db.connect with the newly changed table with
the sqlite file) repeatedly with all vector files for which the category
column in the dbf table is spelled "CAT".
Good work on GRASS 7 folks... its impressive!
Ticket URL: <http://trac.osgeo.org/grass/ticket/2568>
