#2571: Pattern Flag addition to v.patch
Reporter: 3DTOPO | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: normal | Milestone: 7.1.0
Component: Vector | Version: unspecified
Resolution: | Keywords: v.patch, file option, multiple
CPU: | input
Unspecified | Platform: Unspecified
Changes (by wenzeslaus):
* keywords: v.patch => v.patch, file option, multiple input
* milestone: 7.0.0 => 7.1.0
Comment:
G7:r.colors and G7:r.series have option `file` which is an alternative to
`map` and `input` options. It is a path to a text file with names of
raster maps, one map per line. This is simple and solves the problem,
although the naming could be more clear.
I'm not sure how this should work for vector. Particularly, what to with
layers? Should the format be something like the following?
native_vect_name_a 1
native_vect_name_b 1
native_vect_name_c 5
Should the layer be optional? So for layer one (that's the usual default):
native_vect_name_a
native_vect_name_b
native_vect_name_c
It would be up to the module to define if the default layer is something
else, same as with options.
The OGR direct access would require (as far as I understand):
file_path/file_name_a@OGR file_name_a
file_path/file_name_b@OGR file_name_b
file_path/file_name_c@OGR file_name_c
Does this sound reasonable? Will the formats work always?
Comparing to the proposed pattern solution, this should cover more cases
and it should be better for programming. However, it requires G7:g.list
call first in non-programming most cases. Anyway, if I remember correctly,
this was discussed on mailing list and the result was usage of text file.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2571#comment:1>
