#2579: Specify command to be exectued as parameter of grass command
Reporter: wenzeslaus | Owner: grass-dev@…
Priority: normal | Milestone: 7.1.0
Component: Startup | Version: svn-trunk
Keywords: batch job, GRASS_BATCH_JOB, init | Platform: All
Cpu: Unspecified |
To run some modules from outside of GRASS you currently have to either
setup the
[http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
environment yourself] which is hard, error prone and you won't get it
right anyway or you can use `grass` command in a batch mode. For this you
have to specify `GRASS_BATCH_JOB` environmental variable and then call
GRASS GIS:
export GRASS_BATCH_JOB=.../test_script.sh
grass7 ~/grassdata/location/mapset
Although this works it might be quite cumbersome especially in some
languages. For example Python has much smoother interface where you just
specify the script and its arguments:
python .../test_script.py arg1 arg2 ...
The attached patch is introducing an additional interface for the `grass`
command which allows to call scripts like this:
grass7 --mapset ~/grassdata/location/mapset --batch .../test_script.sh
But it actually allows to also use parameters, GRASS modules, and
generally any commands:
some parameters
grass7 --mapset ~/grassdata/location/mapset --batch r.info map=elevation
If you are fine with what is in the rc file, you can use just:
grass7 --batch r.info map=elevation
But I'm not sure if it is a best practice.
I wrote the patch in the way that you don't get any additional output,
just the output from the module, unless something unusual is happening
(e.g., creation of a new location):
$ grass71 --mapset ~/grassdata/location/mapset --batch r.info
map="elevation" -g
north=228500
south=215000
east=645000
west=630000
nsres=10
ewres=10
rows=1350
cols=1500
cells=2025000
datatype=FCELL
ncats=255
I tried to preserve the functionality of `GRASS_BATCH_JOB` including the
GRASS textual output and sanity checks.
When both `GRASS_BATCH_JOB` and `--batch` are provided `--batch` is used
and `GRASS_BATCH_JOB` is ignored as Python documentation says: ''it is
customary that command-line switches override environmental variables
where there is a conflict'' (e.g. `gcc` follows the same practice).
The names `--mapset` and `--batch` seemed to me at best choice, although
there are other good options too such as `--run`.
To test, try something like:
cat > test_script.sh <<EOF
#!/bin/bash
echo "Hello from GRASS GIS (`date`)"
echo "This is what was called: $0 $@"
EOF
grass7 --mapset ~/grassdata/location/mapset --batch test_script.sh some
parameters
grass7 --mapset ~/grassdata/location/mapset --batch r.mapcalc "aaa = 5"
grass7 --mapset ~/grassdata/location/mapset --batch r.info aaa
GUI works too, although I'm not sure if it is useful (could be even
inconvenient for scripting).
From what I see now, the only issue with calling individual modules is
that you cannot (or should not) parallelize the calls of `grass` command
in the same mapset.
== Additional ideas ==
This is out of scope of this ticket but there is a potential to create one
even more powerful interface similar let's say to `git`.
#!sh
mkdir some_project
cd some_project
# init connects to existing database, location and mapset or creates a new
one
# creates .grassrc (.rc or .gisrc) file current directory
grass7 init ~/grassdata/location/mapset [-c | -c geofile | -c
EPSG:code[:datum_trans]]
grass7 import .../some_image.tiff
grass7 run r.info some_image
grass7 run r.mapcalc "improved_image = 5 * some_image"
grass7 export improved_image .../improved_image.tiff
# next time you can cd into some_project directory and commands will work
right away
# because .grassrc file will be already there
Some commands such as `grass7 link` or `grass7 external` might be quite
useful, although they would be, similarly to `grass7 import` and `grass7
export` just appropriate `r.in.gdal`, `r.in.proj`, etc. calls.
It would be even more interesting to have:
grass7 run r.slope.aspect elevation=file://.../elevation.tiff
aspect=file://...aspect.tiff
The `grass` command would have to parse the command line, find the files
which should be maps and link them. And perhaps if it wouldn't be `grass7
run` but something different such as `grass7 runonly`, we could even skip
the `.grassrc` and create location on the fly in `/tmp` and delete it
after execution. If data would be just linked, not imported and exported,
it could be pretty fast. (But obviously we could be hitting issues with
projection and topology here, so it is a bit tricky.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2579>
