#2585: GRASS 7 RC2 - v.what.vect.py
Reporter: stevenpawley | Owner: grass-dev@…
Type: defect | Status: new
Component: Python | Version: unspecified
Keywords: | Platform: All
Cpu: Unspecified |
The script v.what.vect in the GRASS 7 RC2 does not work - a simple patch
is attached and the script which just calls on v.distance now works as
intended.
Thank you for reporting this bug! I fixed that in r64545 in trunk and
r64546 in releasebranch. Could you please test the committed change and
then close the ticket.
