[GRASS-dev] [GRASS GIS] #2586: Display of labels in raster query results window is limited to the first 60 characters
characters
Reporter: pvanbosgeo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.5
Component: Default | Version: svn-releasebranch70
Keywords: | Platform: Linux
      Cpu: Unspecified |
Using the query raster function shows only the first 60 characters of the
raster label.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2586&gt;
characters
Keywords: query | Platform: Linux
      Cpu: Unspecified |
Changes (by annakrat):
  * keywords: => query
  * milestone: 6.4.5 => 7.0.0
Comment:
I assume you are talking about the query dialog. You can make the column
wider to show the entire label, but at least on my system, the place where
the column ends and where you should drag it is not very well visible, so
I enlarged the default width of the column in r64562 and r64563. Let me
know if that's what you meant.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2586#comment:1&gt;
