#2587: copying attribute tables very inefficient if tables are in same database
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.1.0
Component: Database | Version: svn-trunk
Resolution: | Keywords: libdb copy table
Comment (by mlennert):
To reinforce this:
I have a vector map with 881,120 points. I have to loop over this map,
extracting points according to one attribute. When I use v.extract to
extract the points and to create the table it takes quite a long time,
most of it in "writing attributes":
time v.extract produnits_light where="cd_nacebel_2010='27120' and
etab_emploi_onss_2010>0" out=prod_temp --o
real 0m20.183s
user 0m12.872s
sys 0m17.516s
i.e. 20s, although this only extracts 93 points !
Using a script that extracts the points without attribute table and then
creates the table using different tools, it is much quicker. Here's the
script (t.sh):
v.extract -t produnits_light where="cd_nacebel_2010='27120' and
v.db.select produnits_light where="cd_nacebel_2010='27120' and
etab_emploi_onss_2010>0" sep=, file=test.csv --o
v.info -c produnits_light --quiet | cut -d'|' -f1 | sed 's/TEXT/STRING/'
| sed 's/DOUBLE PRECISION/REAL/' | sed 's/\(.\)\(.*\)/"\1\L\2"/g' | paste
-s -d ',' > test.csvt
db.in.ogr input=test.csv out=prod_temp_table --o
v.db.connect -o prod_temp table=prod_temp_table key=cat_
time sh t.sh
real 0m1.241s
user 0m1.000s
sys 0m0.168s
The result is identical except that cat is renamed cat_ by db.in.ogr...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2587#comment:1>
