#2590: t.create fails to create/overwrite a new strds
Reporter: nikosa | Owner: grass-dev@…
Type: defect | Status: new
Component: Temporal | Version: svn-releasebranch70
Keywords: | Platform: Unspecified
Cpu: Unspecified |
The command
`t.create type="strds" title="DMSP-OLS" description="Version 4 DMSP-OLS
Nighttime Lights Time Series" output="ols"`
works fine in G71 (trunk) but fails in G7. The relevant output is:
works fine in G71 (trunk), it doesn't work in G7 (updated last night).
WARNING: Overwrite space time raster dataset <ols> and unregister all
maps.
File "/osgeo/src/grass7_release/dist.x86_64-unknown-linux-
gnu/scripts/t.create", line 83, in <module>
ERROR: Unable to execute transaction:
-- This main()
SQL script generates the table in which all registered GRASS_MAP File
gnu/scripts/t.create", line 79, in main
maps
-- are listed in.
-- semantic, None, grass.overwrite())
This table File "/osgeo/src/grass7_release/dist.x86_64-unknown-linux-
gnu/etc/python/grass/temporal/open_stds.py", line 169, in
open_new_space_time_dataset
will be created for each STDS.
-- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
-- SPACETIME_NAME is a placeholder for specific stds name (SQL compliant):
name_mapset
-- GRASS_MAP sp.insert(dbif)
is a placeholder for specific map type: raster, File
gnu/etc/python/grass/temporal/abstract_space_time_dataset.py", line 366,
in insert
raster3d or
vector
-- This table stores the.ids of the GRASS_MAP maps registered in the
current spacetime GRASS_MAP table
CREATE TABLE SPACETIME_NAME_GRASS_MAP_register (
id VARCHAR NOT NULL, -- This colum is a primary key storing the registered
GRASS_MAP map.ids
PRIMARY KEY (id)
CREATE INDEX raster_map_register_dad84f0878c348b49cf467fc4a689a88_index ON
raster_map_register_dad84f0878c348b49cf467fc4a689a88 (id);INSERT INTO
strds_base ( name ,creator ,mapset ,creation_time ,modification_time
,temporal_type ,id ,semantic_type ) VALUES ('ols' ,'nik' ,'PERMANENT'
,'2015-02-18 13:00:57.586753' ,'2015-02-18 13:00:57.586764' ,'absolute'
,'ols@PERMANENT' ,'mean') ;
INSERT INTO strds_absolute_time ( start_time ,granularity ,id ,map_time
,end_time ) VALUES (NULL ,NULL ,'ols@PERMANENT' ,NULL ,NULL) ;
INSERT INTO strds_spatial_extent ( north ,bottom ,west ,top ,proj ,east
,id
,south ) VALUES (NULL ,NULL ,NULL ,NULL ,'XY' ,NULL ,'ols@PERMANENT'
,NULL)
INSERT INTO strds_metadata ( max_min ,description ,ewres_min ,title
,min_max ,nsres_min ,nsres_max ,number_of_maps ,raster_register ,command
,min_min ,ewres_max ,id ,max_max ,aggregation_type ) VALUES (NULL ,'test'
,NULL ,'test' ,NULL ,NULL ,NULL ,NULL
,'raster_map_register_dad84f0878c348b49cf467fc4a689a88' ,'# 2015-02-18
13:00:57
t.create type="strds" title="test" description="test"
output="ols" --o
' ,NULL ,NULL ,'ols@PERMANENT' ,NULL ,NULL) ;
dbif.execute_transaction(statement)
gnu/etc/python/grass/temporal/core.py", line 955, in execute_transaction
self.cursor.executescript(statement)
sqlite3.OperationalError: table SPACETIME_NAME_GRASS_MAP_register already
exists
Ticket URL: <http://trac.osgeo.org:80/grass/ticket/2590>
